Copper T3 Inlet Gaskets
Old Jan 27, 2005 | 11:45 AM
ExploitedRacing-HR's Avatar
Default Copper T3 Inlet Gaskets
I been thinkin about this for a long time now and have the plans about ready to carry out but i want to get some other opinions first before i do this....
I want to make some T3 Gaskets out of .050" Copper. I feel that .010" SS just isnt cutting it to seal properly. Stainless steel does NOT compress making it unable to seal an imperfect surface at times. Copper on the other hand will mold to the surface when crushed under pressure creating a better seal with no leaks all around.
Do other people see this were im coming from on this?
Old Jan 27, 2005 | 12:31 PM
Ekasey's Avatar
Default Re: Copper T3 Inlet Gaskets (ExploitedRacing)
word that would be pretty cool
Old Jan 27, 2005 | 04:37 PM
turbo gli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">I been thinkin about this for a long time now and have the plans about ready to carry out but i want to get some other opinions first before i do this....
Do other people see this were im coming from on this? </TD></TR></TABLE>
yes its been done befor .. vwvortex some guy made one for his turbo to mani gasket ..
also make some 5bolt t25,28.. housing ... most nissan guys need that gasket but oem steel ones are bank ..
also .. dosnet s.s gaskets have the bumpy sliver coated / black **** to seal it ? u know what im talking about .. it always flaks off when u remove , drop a gasket
Old Jan 27, 2005 | 08:54 PM
Not the ones i been getting, there just regular stainless steel. Copper is still an idea choice in my opinion because it can compress to seal better
Old Jan 27, 2005 | 08:57 PM
Bailhatch's Avatar
Default Re: (ExploitedRacing)
The best choice is planing both surfaces so there is no gasket at all, then you have nothing to blow out or leak or replace.
Old Jan 27, 2005 | 10:44 PM
Thats in a perfect world Bailhatch. Which this isnt. Heat causes metal to warp. Even if it isnt noticable to the human eye you can warp a turbo flange .010" or even .015" which is enough to cause a nice leak. Most people dont have the time, money, or equip. to resurface there turbo and manifold everytime the flange warps.
Old Jan 27, 2005 | 11:20 PM
This One's Avatar
I dont normally use Gaskets, dont seem to have any problems with flange surfaces....
Pretty cool idea i guess for the people trying to track down sealing problems...
Old Jan 28, 2005 | 12:03 AM
untitled's Avatar
Default Re: (This One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by This One &raquo;</TD></TR><TR><TD CLASS="quote">I dont normally use Gaskets, dont seem to have any problems with flange surfaces....
Pretty cool idea i guess for the people trying to track down sealing problems...</TD></TR></TABLE>
w3rd. i ususally weld my turbos to the mani and then weld the mani to the head.
Old Jan 28, 2005 | 01:04 AM
Default Re: (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">
w3rd. i ususally weld my turbos to the mani and then weld the mani to the head. </TD></TR></TABLE>
Must be one of those "low maintance" Setups.
Old Jan 28, 2005 | 01:07 AM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">Must be one of those "low maintance" Setups.</TD></TR></TABLE>
Right Right...
Old Jan 28, 2005 | 07:25 AM
rtype11's Avatar
just use the t3 gasket from Ford off the SVO or supercoupe, metalized paper and crushes to seal imperfections. or use copper spray on any gasket. A pure copper gasket is not maintenance free, they need occasional removal re annealing in oven and cleaning, they shrink and grow a lot shifting them around. you can buy a sheet of gasket copper from various suppliers but it would be way cheaper to go to Ford and shell out the 4.50 for their gasket.
Old Jan 28, 2005 | 07:47 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">Thats in a perfect world Bailhatch. Which this isnt. Heat causes metal to warp. Even if it isnt noticable to the human eye you can warp a turbo flange .010" or even .015" which is enough to cause a nice leak. Most people dont have the time, money, or equip. to resurface there turbo and manifold everytime the flange warps.</TD></TR></TABLE>
Huh, apparently Maine is a perfect world then, because I do this time and time again with no problems at all. And they don't warp over time either.
Old Jan 28, 2005 | 01:50 PM
rioninja's Avatar
I made a gasket out of copper.
It sealed great, but upon removing it a year later it had a few cracks starting to develop. I used 1mm copper sheet.
Old Jan 28, 2005 | 03:34 PM
Zornig's Avatar
Default Re: Copper T3 Inlet Gaskets (rioninja)
Good surfaces dont need gaskets.
But for someone that doesnt have access to surfacing I think its a good idea.
sean-sports
Jan 31, 2007 03:08 PM
mrx
Sep 30, 2005 08:45 AM
icebergli
Jul 28, 2005 03:43 PM
wantboost
Jan 19, 2005 10:24 AM
redboost10
Oct 24, 2003 09:03 AM
