mini-me questions
hi all. Im going to be swapping a d16y8 head on my y7 block soon. ive been reading up on it a bit. couple questions
when reinstalling the new valve cover, I use a rubber gasket between the valve cover and the head? is it hard to make fit? do i use any kind of adhesive or sealant?
also what are the valve cover sealing grommets, do they go under the bolts?
I will likely have a lot more questions as it becomes closer to time for me to do the project.
hmm, but what about sealant? am i supposed to put a dab of sealant on the corners?
another couple questions...
any reason to dismantle the cylinder head? meaning to take the valves and springs out?
I assume if you want to polish the head you have to take it all apart right?
how good is it to replace the valves with racing ones? waste of money?
I want it to be a daily driver that pulls at least 200+ whp on a N/A engine. I might take it to the local autox track for fun.
gonna make it super clean with rims and tint, as a gift for my wife. (its her car).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">You might as well swap in a dohc if you plan on 200+ whp n/a. It will be very hard and very expensive to get close to that kind of numbers with only n/a.</TD></TR></TABLE>
dang 200+. b series for sure or turbo charge d series
the highest I've seen on a sohc vtec N/A is 200 and it had a shitload done port&Polish, cam, valve train etc.. if you want fast and daily driver, b series is the way to go. but it will be a fun project anyway. also the money you spend on the sohc motor to get it to even 160hp you can get a b16 for cheep and have that hp and a stock motor. 200 is easily reachable with b series. you can find obd0 b16 for 600$
Don't quote me on this, but I've read somewhere that a d16 internals can only handle a consistent power of under 180 hp, anything higher, and you have to replace pistons and rods.
But then again, I have seen a SOHC pulling 200 hp with a turbo on stock internals (question is, "how long will it last").
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice »</TD></TR><TR><TD CLASS="quote">Don't quote me on this, but I've read somewhere that a d16 internals can only handle a consistent power of under 180 hp, anything higher, and you have to replace pistons and rods.
I have been turbo for almost a year and I beat the **** out of my car daily. I made 216whp/181wtq at 10psi and 230whp/208wtq at 12psi. This is on a completely stock d16z6.
with your motor on stock internals anything above 11 or 12 psi daily, u will end up throwing a rod or burning the **** out of the pistons, if u turbo u might want some heavy internal upgrades for a SOHC. Believe me i have tried it and blown 2 motors so as most people have said it would be smarter to go to a b series, h22a, or even a k20.
I read that d16Y and d16Z are different, even the head bolts from ARP are different for those two.
I do hope d16Y can handle that much, though, because I'll be putting a bunch of bolt-ons, not to mention a 75-shot ZEX kit.
JENNY_EG6
Jan 16, 2009 10:29 AM
VtecCivic93
Jun 11, 2008 04:16 PM
BDogggUT34
Apr 22, 2005 03:12 PM
