no sensor for IACV
Old Jan 26, 2005 | 04:18 PM
mymeatb18
Default no sensor for IACV
when i swaped my b16 in my crx using my stock harness i came to realize after the swap was done my IACV sensor was not hooked up. upon looking for the sensor i saw that there was no sensor. the motor that was in the car was an obd0 si motor but i believer it had the hf harness. well anyways i found a sensro that fits now it just needs to be wired to my pw0 ecu.
problem is there are two wires but the pinout calls for one wire wut to do?
i beleive the pinout is on connector a slot 10, i also dont know which is slot 10
Old Jan 26, 2005 | 05:04 PM
mymeatb18
Default Re: no sensor for IACV (mymeatb18")
bump
Old Jan 28, 2005 | 02:56 PM
mymeatb18
bump **** u for help
Old Jan 28, 2005 | 03:17 PM
fourthgenhatchB17's Avatar
Look for the plug, it should be there. And when u say "sensor" do u mean plug? The sensor itself would be classified as the IACV itself.
Old Jan 28, 2005 | 05:24 PM
mymeatb18
Default Re: no sensor for IACV (fourthgenhatchB17)
do all honda motors (not sure about carbuerated) have an IACV if so then i guess i should spend more time looking for the "plug"
Old Jan 28, 2005 | 10:35 PM
Your 88-91 CRX has or came with an IACV. The plug is there, even on the HF harness. Maybe someone cut it for some odd stupid reason?
Old Jan 29, 2005 | 12:23 PM
mymeatb18
alright thanks i will check
2jz240sx
Apr 8, 2019 07:37 PM
UNKNOWN_MEMBER
Jun 27, 2005 02:27 AM
yoursupinehead
Mar 23, 2005 12:31 PM
Greg456
Mar 12, 2004 09:24 AM
