whats the diff between obd's
Old Jan 26, 2005 | 04:12 PM
bugster's Avatar
Default whats the diff between obd's
whats the difference between obd0,1,2. do they function different or are the plugs just different. no matter what your car is, when doing a swap, cant you just take the engine, ecu, and wiring harness and switch them all out? i have two 89's, one a crx si and a hatch dx auto. the crx has a sohc zc in it and its lil fun car but i wanted to swap that for something different, like a vtec d or any b series. but someone told me have fun converting the obd1,2. if i do a swap i want it to be from a usdm, ca car so i can get it all legalized. ive heard of conversion harnesses what do those do exactly?
Old Jan 27, 2005 | 05:58 PM
PrettyLude's Avatar
obd2 96 and up
obd1 before 96
obd0 90 and before
Old Jan 27, 2005 | 09:42 PM
bugster's Avatar
Default Re: (PrettyLude)
thanks for that lil tidbit, but that doesnt explain reasons why everyone hates to convert or says its a bitch....i figure they changed for a reason (better?) id like to find out.
Old Jan 27, 2005 | 09:55 PM
PrettyLude's Avatar
the later the year the more wiring you have to do, the more sensitive the onboard diagnostics system gets, i.e. obd2 has trouble codes for misfires for every cylinder as in obd1 doesn't have it
they say its a bitch because of all the wiring
Old Jan 27, 2005 | 10:09 PM
bugster's Avatar
are senors and engines interchangible
Old Jan 28, 2005 | 02:38 AM
untitled's Avatar
Default Re: (bugster)
some are some arent due to the clips being different
Old Jan 28, 2005 | 05:03 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bugster &raquo;</TD></TR><TR><TD CLASS="quote">...i figure they changed for a reason (better?) id like to find out.</TD></TR></TABLE>Government required the engine-control system to be able to detect (by itself) whether the emmissions systems were still working. For example an OBD-1 system has no way of 'knowing' whether the cat is working, or even whether it's still installed.
BaileyJames
Jan 22, 2019 07:17 PM
bethbraun
Feb 20, 2009 02:33 AM
herbalist
Mar 30, 2005 04:38 AM
FritzInTN
Jan 19, 2004 03:51 PM
