when does rev limiter kick in?
Old Jan 26, 2005 | 10:46 AM
JDM00SI's Avatar
Default when does rev limiter kick in?
sup, i have a b16a2 w/ bolt ons and JG cam gears as the only engine internal ( if it is considered an internal) anyways i was gunning it yesterday when i was going into gear 2 i didnt put it in all the way therefore the thing reved extremely high due to the fact it is in nuetral. i remember looking at the rpm at 8200. i havent driven it since but i just worried. it drove home normally, i gunned it on the way back also. but if this ever happens the rev limiter will prevent it from bending valves etc...right?
thanks
Old Jan 26, 2005 | 10:48 AM
JDM00SI's Avatar
Default Re: when does rev limiter kick in? (bigbeasta4)
bump
Old Jan 26, 2005 | 10:58 AM
elrandeeto's Avatar
it should just dont hold it there all day long . your motor is built pretty well for high rpms , a mistake here and there or just pushin it that hard you should be ok just dont make habit of it like everyday
Old Jan 30, 2005 | 06:14 PM
sickerhatch's Avatar
Default Re: when does rev limiter kick in? (elrandeeto)
no i bent my b16 valves with a stock rev limitor
Old Jan 30, 2005 | 06:43 PM
mmuller's Avatar
Mad Scientist
the only way you can bent valves with a stock revlimit is by doing a mechanical over rev.
for example mis-shifting from 3rd to 2nd. when the stock rev limit wont stop the revs from going up
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
gmboogy
Sep 4, 2006 07:59 PM
JDM00SI
Sep 17, 2004 01:14 PM
V-SPEC 1
Jan 1, 2004 06:47 PM
JDM_ITR
Jul 10, 2002 04:24 PM
