New Key
My key is stuck in the ignition and I cant get it out to lock the doors. So I'm currently getting a new ignition and key off of ebay. Now, when I go to the dealer for a new key to get cut for my doors what do I need to bring with?
Thanks for the help
Thanks for the help
have you tried calling a locksmith? when my key broke in the ignition, he was able to get it out...
for the dealer, you should bring your title and drivers license...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Have you tried calling the dealer?</TD></TR></TABLE>
No I haven't yet I figured I would just stop by today since its on my way home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">have you tried calling a locksmith? when my key broke in the ignition, he was able to get it out... </TD></TR></TABLE>
I don't think a locksmith will work because they keys pretty much bent in there. It happend before and I was able to get it out but now its stuck in there.
Does anyone know if theres differences in the lock mechanisms that I should be aware of?
A good locksmith can get that ish out.
I would try that.
Replacing the lock is no fun.
I would try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSB18A1 »</TD></TR><TR><TD CLASS="quote">
like i said, i broke my key into the lock before, and the locksmith got it out with his special tools...i think they were two picks? i forget, but it was broken in the bottom part of it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSB18A1 »</TD></TR><TR><TD CLASS="quote">My key is stuck in the ignition and I cant get it out to lock the doors. So I'm currently getting a new ignition and key off of ebay. Now, when I go to the dealer for a new key to get cut for my doors what do I need to bring with?
Thanks for the help
Is the steering wheel locked? Check by turning the steering wheel while trying to remove ignition key. Sometimes the tires can hold the wheel locked nicely.
Vince
Thanks for the help
</TD></TR></TABLE>Is the steering wheel locked? Check by turning the steering wheel while trying to remove ignition key. Sometimes the tires can hold the wheel locked nicely.
Vince
traumacase
Sep 9, 2007 01:04 AM
liljohnson
Aug 12, 2004 11:48 PM
