civic si & civic ex suspension
Old Jan 13, 2002 | 05:39 PM
tFUnK's Avatar
Default civic si & civic ex suspension
I'm talkin about the newer models... 96-00 ex and 99-00 si... i heard they use the same suspension, (shocks, springs) and are basically the same, but that the si has a front strut bar, rear strut and rear tie bar? Then, someone says that si has a sportier/stiffer shock/spring setup than the ex... does anyone here know? thanks!
Old Jan 13, 2002 | 07:57 PM
96 SOHC VTEC's Avatar
Default Re: civic si & civic ex suspension (tFUnK)
The Si has the bars you were mentioning and has slightly stiffer springs and shocks I believe as well. It doesn't take much aftermarket wise to make your car handle better than a stock Si though.
Old Jan 13, 2002 | 08:15 PM
BagelW's Avatar
The Si does have stiffer springs but they are still not stiff enough.
Old Jan 13, 2002 | 10:02 PM
tFUnK's Avatar
Default Re: civic si & civic ex suspension (bagelw)
so shocks are the same as ex then? or not? well not like it really matters to me anymore *shrug*
Old Jan 14, 2002 | 07:09 AM
CivicV10@18000rpm's Avatar
As far as I know the SI uses both stiffer shocks and springs than the EX.
Old Jan 14, 2002 | 08:16 AM
YodaIsGod
Guest
Posts: n/a
Default Re: civic si & civic ex suspension (CivicV10@18000rpm)
I agree with the suspension not stiff enough. So far, i've just installed springs from the Integra Type-R, much, much better. Shocks will come later.
Old Jan 14, 2002 | 08:54 AM
Rezon's Avatar
Default Re: civic si & civic ex suspension (YodaIsGod)
EX:
22 mm front sway bar
no rear sway bar
no front strut
SI:
26mm front sway bar
16mm rear sway bar
front strut bar
firmer shocks and springs, but not by much
[Modified by Rezon, 5:55 PM 1/14/2002]
Old Jan 14, 2002 | 09:50 AM
Larkin W.'s Avatar
Default Re: civic si & civic ex suspension (Rezon)
EX:
SI:
16mm rear sway bar
correction:
I believe that the si only has a 13mm rear sway bar
Old Jan 14, 2002 | 09:59 AM
Civic242's Avatar
Default Re: civic si & civic ex suspension (EbboyPSi)
EX:
SI:
16mm rear sway bar
correction:
Yes it's a 13mm and that's not thick enough. A 19mm rear bar works wonderfully.
Old Jan 14, 2002 | 11:35 AM
Larkin W.'s Avatar
Default Re: civic si & civic ex suspension (Civic242)
My 22mm Comptech sway/tie bar works amazing. I can't pick much of a better mod. Now i need better seats. SI seats suck the dillz.
Old Apr 13, 2016 | 07:45 PM
USernie1982's Avatar
okay what I need to know here are the EX suspension parts interchangeable with the SI parts
Old Apr 13, 2016 | 08:33 PM
eghatch9295's Avatar
Stancetard Hate Monger
hop in your time machine and travel back 14 YEARS to participate in this thread.
SYR_Civic_06EX
Honda Civic (2006 - 2015)
Aug 16, 2008 12:01 PM
mushu315
Oct 31, 2004 07:18 PM
mushu315
Jun 24, 2004 12:38 PM
lliew
Jun 19, 2002 01:13 PM
