civic si & civic ex suspension
I'm talkin about the newer models... 96-00 ex and 99-00 si... i heard they use the same suspension, (shocks, springs) and are basically the same, but that the si has a front strut bar, rear strut and rear tie bar? Then, someone says that si has a sportier/stiffer shock/spring setup than the ex... does anyone here know? thanks!
Re: civic si & civic ex suspension (tFUnK)
The Si has the bars you were mentioning and has slightly stiffer springs and shocks I believe as well. It doesn't take much aftermarket wise to make your car handle better than a stock Si though.
Re: civic si & civic ex suspension (bagelw)
so shocks are the same as ex then? or not? well not like it really matters to me anymore *shrug*
As far as I know the SI uses both stiffer shocks and springs than the EX.
Guest
Posts: n/a
Re: civic si & civic ex suspension (CivicV10@18000rpm)
Re: civic si & civic ex suspension (YodaIsGod)
EX:
22 mm front sway bar
no rear sway bar
no front strut
SI:
26mm front sway bar
16mm rear sway bar
front strut bar
firmer shocks and springs, but not by much
[Modified by Rezon, 5:55 PM 1/14/2002]
no rear sway bar
no front strut
SI:
26mm front sway bar
16mm rear sway bar
front strut bar
Re: civic si & civic ex suspension (Rezon)
EX:
SI:
16mm rear sway bar
SI:
16mm rear sway bar
I believe that the si only has a 13mm rear sway bar
Re: civic si & civic ex suspension (EbboyPSi)
EX:
SI:
16mm rear sway bar
correction:
SI:
16mm rear sway bar
correction:
Re: civic si & civic ex suspension (Civic242)
My 22mm Comptech sway/tie bar works amazing. I can't pick much of a better mod. Now i need better seats. SI seats suck the dillz.
SYR_Civic_06EX
Honda Civic (2006 - 2015)
08-16-2008 12:01 PM
mushu315
10-31-2004 07:18 PM
