Automatic to 5spd???????
Old Jan 13, 2002 | 04:05 PM
BuddhaSiR's Avatar
Default Automatic to 5spd???????
I've got a 91 Acura integra automatic. I want to change it to 5spd. i was wondering what tranny mount i should use? Do I have to use a custom mount? if so, Who has one? Input from people who have done this swap is needed.
Old Jan 13, 2002 | 07:01 PM
iceburgslim's Avatar
Default Re: Automatic to 5spd??????? (BuddhaSiR)
I've never done the sawp, but I will go out on a limb and say that you will need the 5-speed tranny mount. You will also need the pedal assembly (you're gonna need a clutch pedal!), clutch cable, and MAYBE axles (cant say for sure about that, double check the parts #'s with your Acura dealer)..you also may want ot get a 5-speed ECU, but I dont know for sure if you will need it. I hope this helps! Later!
Old Jan 13, 2002 | 07:15 PM
BuddhaSiR's Avatar
Default Re: Automatic to 5spd??????? (iceburgslim)
I'm sure someone out there has done this swap before. Need some help here guys. I've asked almost everyone i know. So, i turn to you guys.
Old Jan 13, 2002 | 11:29 PM
salbaje's Avatar
ive done this swap and i can get you all the parts you need. email me if you want
Old Jan 14, 2002 | 11:22 AM
td04civic's Avatar
I did the swap on my civic. But it should be similar for a teg. You'll need the following parts:
ECU
Manual Trans.
Shift linkage
Shifter
Shiftboot
master cylinder
slave cylinder
clutch resorvoir
clutch lines
flywheel
flywheel cover
manual trans. mounts
if you want you could get a manual guage cluster
clutch pedal
brake pedal
what you should do is go to your acura dealer and ask them for a print out of the diagrams for the master/slave cylinder,pedal assy., and shift linkage because you will need to buy a bunch of brackets and nuts and bolts. Keep the diagrams and give it to whoever is doing the install. Good luck
Troy
Old Jan 14, 2002 | 11:41 AM
rainforest's Avatar
you will use the 5speed mount and the clutch master cylinder.
Old Jan 14, 2002 | 04:21 PM
AmauryR's Avatar
Default Re: Automatic to 5spd??????? (:honda: )
I did the swap too on my older (rip) '93 civic dx. Should be pretty close, you'll need the tranny (cable) for your car (and a new clutch), flywheel, the shift linkage/shifter with it, clutch cables, pedal assembly, cut a hole under the auto shifter 4 the shifter, and I think you modify the upper tranny mount (I did) and use the 5-speed mount, you'll also need (I think) the 5-speed axles, also disable the automatic computer (blue box in civics) and replace the computer you have with a 5-speed integra ecu (90-93). Also remove the main part of the auto-shifter, but keep the part that plugs into the harness, then run 2 lines from the reverse sensor on the tranny to the [R] shift position (think its 2 yellow wires, check the schematics) on the old auto-box and you'll have reverse lights. Baam, you'll be str8 for the swap. Not impossible, jus a slight pain. L8R.
[Modified by SKiLLz-R, 1:23 AM 1/15/2002]
Old Jan 14, 2002 | 08:39 PM
BuddhaSiR's Avatar
Default Re: Automatic to 5spd??????? (SKiLLz-R)
simple Question.... Has anybody ever done an auto to manual conversion on a 90-93 model Acura Integra???????????? I dont want to hear about your civic swaps anymore. civic and integra two different cars here. please anybody with info about 90-93 INTEGRAS PLEASE POST. ALL I NEED TO KNOW ABOUT IS THE TRANNY MOUNT. i know about the ecu,clutch pedal, clutch cable, flywheel, clutch, shift linkage, axles, etc. etc. etc. etc. ALL I NEED TO KNOW ABOUT IS THE FREAKIN MOUNT.
Old Jan 14, 2002 | 09:18 PM
speck102's Avatar
civics and teggys are not that fifferent, they are actually pretty simular.
Old Jan 15, 2002 | 10:23 AM
nodoubt711's Avatar
they still talkin about their civis james?
hey, who wants to race my maxima?
the shiet runs 11's biatch!
Old Jan 15, 2002 | 03:49 PM
J T*'s Avatar
Default Re: Automatic to 5spd??????? (nodoubt711)
since we're on the subject, how hard is this conversion compared to a basic motor swap?
Old Jan 15, 2002 | 07:54 PM
99GS's Avatar
u r an idiot
Old Jan 16, 2002 | 06:09 AM
sol-man's Avatar
Default Re: Automatic to 5spd??????? (td04civic)
Hey Troy
Where did you get your tranny swap done?
Thanks
Old Jan 16, 2002 | 06:15 AM
Big James's Avatar
New User
And you are?
Anyway, as far as the Integra goes, a buddy of mine did it, I will ask him tonight about the mount, and post tomorrow if no one has answered yet.
Old Jan 16, 2002 | 06:47 AM
nodoubt711's Avatar
Default Re: Automatic to 5spd??????? (Big James)
i am your daddy
Old Jan 16, 2002 | 09:14 AM
td04civic's Avatar
Default Re: Automatic to 5spd??????? (sol-man)
sol-man, I got the swap done by the shop called BOR's Auto repair. There pretty good. My swap came out w/out any problems.718-565-8200. There in NYC.
Old Jan 16, 2002 | 12:58 PM
sol-man's Avatar
Anyone special I have to speak to?
Did they get all the parts for you?
Thanks
Old Jan 16, 2002 | 07:16 PM
kikkoboyie's Avatar
New User
why would you have to swap in a different axle for the swap? i dont get it... never heard of that before
when you take out the auto tranny, are any parts of the original tranny used w/ the 5-speed tranny, or is the complete automatic tranny taken out all at once?
im accumulating parts for my swap too....
Old Jan 24, 2002 | 07:06 PM
kikkoboyie's Avatar
New User
Default Re: Automatic to 5spd??????? (kikkoboyie)
boom
Old Jan 24, 2002 | 09:08 PM
Vracer111's Avatar
I did the tranny swap on my '90 integra GS. The only manual tranny Mount I used was the passenger side one (kept the auto front and rear mounts)...It did work, but I do think that there is currently something wrong with the setup as there is definate vibration and clunking after the car has been started a while (has been on blocks the last 5 months as it's no longer street legal - it's being turned into a race car...slowly). I have heard that there needs to be some sort of fabrication for a proper rear mount on the G2 but I wouldn't know what it should be.
As for the CV shafts, they are the same for auto or manual - the only difference is the intermediate shaft, you will need one for a manual integra.
Old Feb 1, 2002 | 01:23 AM
kikkoboyie's Avatar
New User
Default Re: Automatic to 5spd??????? (Vracer111)
thanx
Old Feb 1, 2002 | 06:25 AM
redcivic2623's Avatar
Troy
How much did the swap run you?
Thanks
Chris
Old Feb 1, 2002 | 09:27 AM
td04civic's Avatar
Default Re: Automatic to 5spd??????? (redcivic2623)
The swap cost me $2500 for parts and labor. All my parts were new except the tranny and flywheel. Checkout Sohfast.com they sell alot of civic parts for cheap.
laters
Troy
JDM-EJ1
Feb 20, 2005 06:48 PM
95CIVICMAN95
Jul 31, 2004 01:32 AM
DA6righthand
Jan 8, 2004 10:19 PM
AznInvasion
Sep 12, 2003 06:19 PM
BuddhaSiR
Jan 13, 2002 07:24 PM
