civic 93 not start when hot
Old Jan 25, 2005 | 05:40 PM
norr's Avatar
Default civic 93 not start when hot
need help
i got civic 2dr 93 i got new main relay, fuel regulator, clear distributor cab, on it
the problem is the engine will not start when hot "only". it turn it has spark fuel presure is good, main relay is brand new.can anyone help???????????
Old Jan 25, 2005 | 06:06 PM
civictildeath's Avatar
Default Re: civic 93 not start when hot (norr)
well by hot do you mean running temp or like overheating??
Old Jan 25, 2005 | 06:10 PM
hctjohnson's Avatar
i would be willing to bet that it needs an ignitor and or coil, does it ever stall when your driving it hot.
Old Jan 25, 2005 | 07:08 PM
norr's Avatar
hot at driving temp.not overheat. and sometime if i park under the sun light it not start too. i was thinking about the ECU. i checked by jump the ecu service cable.it gave me just the solid light no flash. what does it mean?
Old Jan 25, 2005 | 08:17 PM
norr's Avatar
Default Re: civic 93 not start when hot (civictildeath)
driving tempn
Old Jan 25, 2005 | 08:32 PM
dantastic's Avatar
according the the haynes manual, hard warm starting could be due to a clogged fuel filter....
Old Jan 26, 2005 | 07:42 AM
Zekers's Avatar
My friend has the same problem on his RX7 which is an 88. He said after he pulled all of the emissions from under the hood it started doing it. He hasn't fixed it yet. He just has to try and try and finally it starts up. Only happens when the engine is at operating temp though.
Old Jan 26, 2005 | 08:34 AM
Jmunk's Avatar
The RX-7's problem is likely due to the injectors on those. Those years are known to leak and flood the motor.
novic
Nov 25, 2015 01:56 AM
boostedbc
17
Jun 6, 2013 09:48 AM
DG19
Mar 6, 2011 04:39 PM
onthagozc
32
Aug 24, 2009 07:54 PM
mcwave
13
Jul 26, 2005 01:15 PM
