93 civic si - won't start
Old 11-24-2015, 12:51 PM
novic's Avatar
Default 93 civic si - won't start
Hi, guys I have a 93 honda civic si comletely stock. My problem is when I drive and then park after 10 minutes ill go to start it and it wont start. fuel pump will not prime and it will just crank but wont turn over. The check engine light stays on but if i leave the key on engine off for about 10-15 minutes the check engine light goes off and then it will prime. I have taken my car to a shop and they have replaced ignition switch, ecu, fuel pump, coolant temp sensor and main relay. I feel like I might as well do this my self since Im only dumping out money. the shops next guess is the distributor before i change that any one got any ideas?
Old 11-24-2015, 01:34 PM
delsolintegra's Avatar
Default re: 93 civic si - won't start
Ground wires at the thermostat housing have good contact. This is the ground point for the ECU.
Old 11-24-2015, 04:11 PM
dannyn502's Avatar
I cleaned it up good already still same thing
Old 11-24-2015, 06:22 PM
egsleepercivic's Avatar
check this if the fuel pump is priming intermittently
http://webcache.googleusercontent.co...&ct=clnk&gl=us
Old 11-24-2015, 10:51 PM
yippee-ki-yay
eHMxhACk's Avatar
Why not pull the CEL code when the light is on?
eH.
Old 11-25-2015, 01:56 AM
Maybe a clog in the fuel lines causing back pressure on the fuel pump.
Check fuel filter, fuel pressure, fuel pressure regulator.
that747guy
34
01-02-2021 09:27 PM
civicali
12
05-24-2019 05:01 PM
DG19
11-01-2011 07:57 PM
DG19
03-06-2011 04:39 PM
blaze_125
56
07-13-2010 07:00 PM
Quick Reply: 93 civic si - won't start
