Axles
Old Jan 24, 2005 | 10:18 PM
DevilryEK's Avatar
Default Axles
Alright I got everthing on my car disconnected, except axles .. i broke the center bolt (not sure what its called) now i am disconnected the control arm.. which I was told is the bolt on the very bottom.. i took out the pin.. and it WILL not come lose.. im using a very strong large breaker bar.. the whole car is almost coming off the jack stands.. it seems like its turning.. but wont break lose.. am i doing something wrong? thanks guys for the help
Old Jan 24, 2005 | 10:22 PM
SOHC4life 96's Avatar
Default Re: Axles (DevilryEK)
I think you are going at the ball joint. Put those back in and look for the bolt that is connecting that straight piece of metal that comes out from the middle of the car and connects to the bottom of the shock and then to the place where the brakes are.
Old Jan 24, 2005 | 10:25 PM
DevilryEK's Avatar
Default Re: Axles (SOHC4life 96)
alright thanks, is there by chance anyone who can give me an illustration? I just dont wana screw this up
Old Jan 24, 2005 | 10:28 PM
I'll go take a picture tomorrow. It's to clold and late right now.
Old Jan 24, 2005 | 10:50 PM
DevilryEK's Avatar
cool thanks man
Old Jan 24, 2005 | 10:51 PM
DevilryEK's Avatar
do i need to worry about anything poping out at me? .. springs.. etc.. anything?
Old Jan 24, 2005 | 11:10 PM
lazynok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">I think you are going at the ball joint. </TD></TR></TABLE>
i cant tell if he really truely does mean the balljoint. but if so go get this tool.
free at autozone (20 dollar deposit... loaner tool)
this tool is amazing. i almost didnt want to return it.. then i remembered i'm going away to college and wont need it (blah.. i should have got this tool 4 motor swaps ago )
Old Jan 24, 2005 | 11:56 PM
Stoich EG2's Avatar
Default Re: Axles (lazynok)
Old Jan 25, 2005 | 03:25 AM
menkio's Avatar
Default Re: Axles (Advan06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
nice reply... why don't you put it somewhere
Old Jan 25, 2005 | 03:34 AM
ironlung78's Avatar
Default Re: Axles (menkio)
you can also spray some p & b blaster down in there and tap the side of it with a mallet as your letting it down. the vibration along with the weight of the car should break it free.
If that doesn't work you could apply some heat to it with a propane torch and do the same as previously mentioned. this is usually a last resort because you'll end up melting the boot and having to buy a new one
beerbongskickass's Avatar
You need to get a big hammer and hit that flat spot next to the ball joint, it will come lose unless you hit like a girl. Make sure you don't hit the ball joint though.
Old Jan 25, 2005 | 01:52 PM
DevilryEK's Avatar
Default Re: Axles (beerbongskickass)
man i cannot get out the ball joint bolt .. it wont budge.. im using a 4' iron breaker bar and everything.. anyone got some ideas?
Old Jan 25, 2005 | 02:17 PM
RCautoworks's Avatar
Watch this video
http://portfolio.iu.edu/bchang...I.AVI
mfisher1987
Transmission & Drivetrain
Jan 25, 2015 08:39 PM
Metalluthier
10
Oct 30, 2006 12:51 AM
freshvibes
Nov 16, 2005 11:35 PM
R_type
May 23, 2005 09:17 AM
SprayinCX
23
Jul 19, 2003 06:48 PM
