integra trailing arms for my 94 coupe... some help please.
Old Jan 23, 2005 | 11:43 AM
B16EJ's Avatar
Default integra trailing arms for my 94 coupe... some help please.
I got some integra (94-97 rs) trailing arms and 40/40 prop valve for my 94 coupe and I was just wondering because I've come across conflicting information while searching and I'm looking for the concrete answer to my question: I don't have the e-brake cables, plus I'm a lazy **** so instead of replacing both trailing arms can I just replace the brake/hub assemblies? if I just change that will I still have an e-brake cable issue? I have the integ soft brake lines, so I'm ok there it's just I cannot find integ e-brake cables any where and it's bloody expensive new, plus changing just the hubs seems like an easier fix.
Old Jan 23, 2005 | 11:46 AM
Tiferet's Avatar
Its much easier to replace the entire assembly, you have to pull it off anyways, if I remember right, dto do it the way you want too.
Old Jan 23, 2005 | 11:58 AM
B16EJ's Avatar
Default Re: (L.D.S. Construction)
bump... i want to know this.
Old Jan 23, 2005 | 12:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (B16EJ)
Drum Cables will NOT work with rear discs (if that is what your asking). If you swap out the spindles, the only thing that saves you from is having to remove & replace your whole trailing arm.
I am not sure which rear disc E-brake cables work the best on a coupe. Mabey sombody else could help out...
Old Jan 23, 2005 | 12:24 PM
2lua's Avatar
Default Re: (94eg!)
use 99-00 si or integra parking cable. use can get them new at the local autozone, advanceautopart, or napa.
Old Jan 23, 2005 | 12:31 PM
hatchi's Avatar
Default Re: integra trailing arms for my 94 coupe... some help please. (B16EJ)
Yes its easier to replace complete assembly. I have ebrake cables if interested
Old Jan 23, 2005 | 02:23 PM
B16EJ's Avatar
Default Re: integra trailing arms for my 94 coupe... some help please. (hatchi)
thanks guys
Armada
Apr 20, 2010 06:48 AM
98couperc4
Apr 14, 2010 04:41 AM
dj theoretic
Jul 8, 2008 05:19 PM
chinoty
Suspension & Brakes
Jan 1, 2007 01:03 PM
sekone
11
Jul 26, 2002 11:18 AM
