obd2 fucked up!!
Old Jan 23, 2005 | 11:32 AM
JFG Kevin's Avatar
Default obd2 fucked up!!
So all i was tryin to do last night was put in a header with a test pipe. i had to extend the secondary o2 sensor for the test pipe. So i cut the o2 sensor wires and extended the wire after that i put in everything (header and test pipe) and started up the car. My car pulled codes, a 20 code and a 65 code. 20 is an ELP code forgot what it stands for and it pull a 65 which is secardary o2 sensor heater fault. What's wrong anybody had this experiences before?
Old Jan 23, 2005 | 04:52 PM
quik1's Avatar
Default Re: obd2 fucked up!! (aznstyler119)
I would check for continuity on all of the wires but it may still show an error code because with a test pipe the secondary o2 sensor needs to read different than the primary and with a test pipe it won't read different. You could try grounding the sensor to the exaust somewhere and plug the bung.
Old Jan 23, 2005 | 06:27 PM
JFG Kevin's Avatar
Default Re: obd2 fucked up!! (quik1)
i found the problem. it was the alternator fuse blown...
mxracer420
Mar 25, 2010 04:33 PM
sickofitall1113
Jun 9, 2005 12:18 PM
Chris_Bye
May 1, 2005 07:56 AM
RISING SUN RACING
Jan 17, 2003 09:53 AM
amrintegra
Nov 5, 2001 07:21 AM
