sohc fouling plug question
Old Jan 22, 2005 | 08:46 PM
decible01's Avatar
Default sohc fouling plug question
my friend has a 90 civic dx with a 1.6 sohc. It has a d15b7 head with diy port work, exospeed 909 cam everything else is pretty much stock. It keeps fouling plugs out fast, I changed them about a month ago and I just had to change them again. what could be causing this?
Old Jan 23, 2005 | 05:15 AM
Chiovnidca's Avatar
Default Re: sohc fouling plug question (decible01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decible01 &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 90 civic dx with a 1.6 sohc. It has a d15b7 head with diy port work, exospeed 909 cam everything else is pretty much stock. It keeps fouling plugs out fast, I changed them about a month ago and I just had to change them again. what could be causing this?</TD></TR></TABLE>
Is it using oil? running rich? Right plugs? Is the engine in good mechanical condition? Compression test?
Old Jan 23, 2005 | 09:30 AM
decible01's Avatar
Default Re: sohc fouling plug question (Chiovnidca)
runs fine with new plugs in, does run a little rich. doesn't use oil, I haven't ran a compression test.
Old Jan 23, 2005 | 05:38 PM
decible01's Avatar
bump, please help friend needs it......
Old Jan 24, 2005 | 05:48 AM
JimBlake's Avatar
"Fouled" plugs doesn't narrow it down much... Look on http://www.ngksparkplugs.com for a set of pictures of spark plugs. What do they look like after they're 'fouled'. Oily? Too rich? Too lean? Too hot? Eroded? Can't help much until you say what's happening to them.
Old Jan 24, 2005 | 12:12 PM
decible01's Avatar
Default Re: sohc fouling plug question (JimBlake)
its like carbon build up, not really oily, but black. I tried hitting one with a wire brush, the stuff was pretty hard to get off. it does run kinda rich. Should I try a hotter plug?
Old Jan 24, 2005 | 05:45 PM
decible01's Avatar
bump
Old Jan 25, 2005 | 03:57 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decible01 &raquo;</TD></TR><TR><TD CLASS="quote">... it does run kinda rich. Should I try a hotter plug?</TD></TR></TABLE>Maybe drop back the fuel so it's not so rich? Then try a hotter plug. Maybe one or the other will work better, you might not have to do both.
Old Jan 25, 2005 | 09:59 AM
decible01's Avatar
thanks allot, I will mess with it tonight or tomorrow.
Night_Minx
Jan 20, 2004 03:49 PM
boosted_dc2
Nov 6, 2003 12:36 AM
Pengo
Oct 26, 2002 03:43 PM
Hybrid
May 4, 2002 10:10 AM
brcivic411
Jan 21, 2002 07:28 PM
