Spark plug help????
Old Sep 10, 2002 | 12:48 PM
boosted_dc2's Avatar
Default Spark plug help????
im wondering what plugs i should be running and what they should be gapped at??? i have a 94 gsr with a drag 3 turbo kit on it (t3/t4). im runing like 8 lbs. what plugs do you guys recomend for use thanks!!!!!!
Old Sep 10, 2002 | 01:03 PM
ekb18c's Avatar
Default Re: Spark plug help???? (hooked_up_gsr)
If you do a search, the answers will come. It's been cover so many times.
HTH
Old Sep 10, 2002 | 01:13 PM
b18bturbo's Avatar
Default Re: Spark plug help???? (ekb18c)
to end the confusion and your search bcpr7es11 gapped .028-.032 or bkre711 ngk plugs
Old Sep 10, 2002 | 01:43 PM
turbosol's Avatar
Default Re: Spark plug help???? (b18bturbo)
1095 is the NGK stock # for the bcpr7es-11, most autoparts store go by this .
Old Sep 10, 2002 | 01:56 PM
ladysman's Avatar
Are these the same gap numbers if one has an MSD box and coil?
Also, does it matter whether it is a SOHC or DOHC?
Thanks
Old Nov 5, 2003 | 08:04 PM
Del_Slowest's Avatar
Default Re: Spark plug help???? (ladysman)
Someone answer his question. Do DOHC spark plugs work in SOHC motors. I have a SOHC motor and everyone is saying to use NGK bcpr7es-11 . However my question is do they work for DOHC and SOHC motors. or should us SOHC motor ppl get a different plug.
And no this hasn't been covered. i've read every sing spark plug thread on H-T tonight.
Old Nov 5, 2003 | 08:18 PM
PrecisionH23a's Avatar
Default Re: Spark plug help???? (turbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol &raquo;</TD></TR><TR><TD CLASS="quote">1095 is the NGK stock # for the bcpr7es-11, most autoparts store go by this .</TD></TR></TABLE>
Do not get the -11's. Same plug as the 3330's but they are actually gapped to a .044, what you want is the bcpr7es that comes gapped to a .033-.035 gap. It is part number 3330 at any of your local auto stores. The good thing about the smaller gap size is that it is less bending the actual tip has to endure which can make it weaker.
Yes you can run it in a SOHC and a DOHC with no problems.
Old Nov 5, 2003 | 08:31 PM
Default Re: Spark plug help???? (GudeH23a)
how come everyone in this post says to use the 11's. Seems like they wouldn't have to regap the plug as much if they would just go with the part number you gave me. Are they just being dumb ar do the 11's work better with B series?
Old Nov 6, 2003 | 12:03 AM
B_1_8_hatch's Avatar
Default Re: Spark plug help???? (Del_Slowest)
what about NGK spark plugs 2975? i think they are zfr7f-11 can remember the number exactly.
Old Nov 6, 2003 | 12:36 AM
MaxSterling's Avatar
Default Re: Spark plug help???? (93hb)
get the ngk's w/out -## (gap numbers) b/c they are pregapped to 32
spoonin ef9
Feb 28, 2007 01:02 PM
b20turbojason
Aug 4, 2004 02:25 PM
Night_Minx
Jan 20, 2004 03:49 PM
Pengo
Oct 26, 2002 03:43 PM
lucas569
Feb 16, 2002 08:38 PM
