hks racing bov quetion
Old Jan 12, 2002 | 03:34 PM
Brian_92GSR's Avatar
New User
Default hks racing bov quetion
I've got an hks racing bov - it has a vaccum source on the top port, and is open on the bottom port. Is the valve supposed to be open at idle? If I pull throttle cable just a little it shuts. Is this normal?
Old Jan 12, 2002 | 03:36 PM
JM Performance's Avatar
Default Re: hks racing bov quetion (Brian_92GSR)
Think so.
Old Jan 13, 2002 | 01:44 AM
turbopimp's Avatar
If this is the old HKS racing bov there is a bolt on top to adjust the spring tension. Turning this bolt clockwise will increase the tension and require more vaccuum to open it the valve, so if you want to close the valve at idle to prevent unfiltered air from entering the engine, crank the bolt down...
Old Jan 14, 2002 | 02:49 PM
New User
Default Re: hks racing bov quetion (turbopimp)
Well, the f-max kit came with a smal k&n filter that fits right on to the blow-off valve, so I assume it goes on there for just that reason.
Eklsv-t
Nov 23, 2007 06:00 AM
boostedK20a2
Jan 30, 2006 07:42 PM
skrewdlude
Jul 11, 2002 10:08 PM
TurbodCX
Feb 12, 2002 11:57 AM
