Main Stud and Bearing Question....
Old Jan 22, 2005 | 07:22 AM
Baggy Spandex's Avatar
Default Main Stud and Bearing Question....
Alright, im in the process of trying to complete an ls/vtec...a couple of problems have arose... I want to purchase a set of ARP Main studs, but the problem is i only see them listed anywhere for either a GSR or a B16A...now i know that GSR's had block girdles, and some B16A's did too, but do i use one of these sets or will they be too long due to the girdle clearance the studs have to clear?
Also...the biggest problem i have to figure out is...Block is from one Integra, crank is from another Integra, and rods are from yet another Integra...yep a mutt of a motor. Now, to my knowledges furthest extent, NOTHING has ever been cut (machined). Could i get away with just ordering a standard ACL bearing set, or will the mixture of parts throw it off?
Old Jan 22, 2005 | 08:17 AM
b18cls1's Avatar
Default Re: Main Stud and Bearing Question.... (OneFiveAlive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneFiveAlive &raquo;</TD></TR><TR><TD CLASS="quote">Alright, im in the process of trying to complete an ls/vtec...a couple of problems have arose... I want to purchase a set of ARP Main studs, but the problem is i only see them listed anywhere for either a GSR or a B16A...now i know that GSR's had block girdles, and some B16A's did too, but do i use one of these sets or will they be too long due to the girdle clearance the studs have to clear?
Also...the biggest problem i have to figure out is...Block is from one Integra, crank is from another Integra, and rods are from yet another Integra...yep a mutt of a motor. Now, to my knowledges furthest extent, NOTHING has ever been cut (machined). Could i get away with just ordering a standard ACL bearing set, or will the mixture of parts throw it off? </TD></TR></TABLE>
ls \ b16 use the same rod bearing gsr / itr use another as far as girdles go the b16a dosent have one so b16/ls studs are the same. hope this helps
Old Jan 22, 2005 | 05:40 PM
Default Re: Main Stud and Bearing Question.... (b18cls1)
okey doke, one problem out of the way, thank you...
Now on with my bearing question.....
Old Jan 22, 2005 | 06:12 PM
mmuller's Avatar
Mad Scientist
if the block/ crank allows for..
what are the #'s and letters on the block and crank?
Old Jan 23, 2005 | 05:13 AM
NJIN BUILDR's Avatar
The ACL's should work fine for you.You just need to plastigauge to be sure.I would do it even with oem bearings.
Glenn
Old Jan 23, 2005 | 05:20 AM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneFiveAlive &raquo;</TD></TR><TR><TD CLASS="quote">okey doke, one problem out of the way, thank you...
Now on with my bearing question.....</TD></TR></TABLE>
what block and what crank are they?
b18a/b b17a b18c??
Old Jan 23, 2005 | 10:25 AM
86si's Avatar
use the color system to determine bearing size, give me the colors you need and
i can get them at a good price.
-Dave O-
Old Jan 25, 2005 | 06:20 PM
Default Re: Main Stud and Bearing Question.... (86si)
okay, block is a B18A1, Crank is a B18A1, and the rods are B18B1...
Old Jan 26, 2005 | 12:32 PM
b18cls1's Avatar
just get ls rod and main bearing kit
Old Jan 26, 2005 | 01:08 PM
mmuller's Avatar
Mad Scientist
we need the numbers and letters stamped on the block/crank.
Old Jan 27, 2005 | 03:16 AM
b18cls1's Avatar
Default Re: Main Stud and Bearing Question.... (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">we need the numbers and letters stamped on the block/crank. </TD></TR></TABLE>
he stated he was going to use acl if going with oem yes we need the #s
Old Jan 27, 2005 | 06:31 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">he stated he was going to use acl if going with oem yes we need the #s</TD></TR></TABLE>
you cant always go with acl's; you can only use them if your block/crank allows for.
Old Jan 27, 2005 | 01:10 PM
b18cls1's Avatar
you cant always go with acl's; you can only use them if your block/crank allows for.</TD></TR></TABLE>
right i was just saying that he stated he wanted to use acls but you should look at athe # codes
Old Feb 8, 2005 | 04:52 PM
9SECQTR's Avatar
HI
Old Feb 22, 2005 | 08:25 PM
dunkd's Avatar
Default Re: Main Stud and Bearing Question.... (9SECQTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9SECQTR &raquo;</TD></TR><TR><TD CLASS="quote">HI</TD></TR></TABLE>
HEY DUDE
Old Feb 22, 2005 | 08:37 PM
9SECQTR's Avatar
Default Re: Main Stud and Bearing Question.... (dunkd)
lol what up
BlwnBlue
Dec 20, 2007 11:43 AM
blackcrx16
Oct 15, 2007 06:45 AM
b18ek670
26
Aug 31, 2006 10:11 PM
tilt.
Sep 13, 2004 03:19 PM
JustLooking
Nov 23, 2003 02:12 PM
