Need Help! Maintainence Required Light Flashing!
Old Jan 22, 2005 | 06:25 AM
CleanShaven's Avatar
Default Need Help! Maintainence Required Light Flashing!
This morning i started my car and my maintainence required light started to flash. I counted the number of flashes it flashes 10 times and then shuts off. Is this some kind of code and how do i check and fix the problem.?????????
Old Jan 22, 2005 | 06:33 AM
1115R's Avatar
its called search!!
im assuming u own an itr... all that means its time for maintance, honda does it so u dont forget to take it to the shop and let them charge u for dumb things... the get it off, turn the power on in the car reach under the dash u will see a light blue button push and hold and ur all good to go
Old Jan 22, 2005 | 06:36 AM
Bbasso's Avatar
Default Re: Need Help! Maintainence Required Light Flashing! (CleanShaven)
Did you bother to read the FAQs ?
Maintainance Light - How to disable the GREEN LIGHT from FLASHING!
https://honda-tech.com/zerothread?id=379960
Old Jan 22, 2005 | 06:39 AM
Default Re: Need Help! Maintainence Required Light Flashing! (Bbasso)
its a yellow light and where underneath my dash? what causes it to turn on is there a way to diagnose the code????????
Old Jan 22, 2005 | 06:43 AM
b19coupe's Avatar
Read much? The "Maintenance Required" is a reminder only, triggered by mileage. There are no "codes".
As posted above :
<FONT SIZE="10">READ</FONT> the link.
Old Jan 22, 2005 | 06:50 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Need Help! Maintainence Required Light Flashing! (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">As posted above :
<FONT SIZE="10">READ</FONT> the link.</TD></TR></TABLE>
Maybe you are new to computers?
Use your mouse to put your cursor (the arrow) over the website address above (the thing that starts with http://). It should change to a pointing finger. Then click the left mouse button. This will make your browser show you the previous topic here on honda-tech. READ IT. It will answer your question.
Old Jan 22, 2005 | 06:53 AM
BudMan's Avatar
Default Re: Need Help! Maintainence Required Light Flashing! (nsxtasy)
Go visit http://www.itrca.com/FAQ/faq.php
There are many subjects that any new R owner should get familiar with. If you have any questions about what you read - just hollar - jeff@itrca.com.
Old Jan 22, 2005 | 06:58 AM
1115R's Avatar
wow!! maby u shouldent own an R if it was a check engine light flashing that another story then there would be a trouble code but the maitnance required it not ****!!
Old Jan 22, 2005 | 08:38 AM
Default Re: (1115R)
you guys are a bunch of dorks, i asked a simple question that you're all too "cool" to answer. and half of you cant even spell correctly. Ive done all the work on my car including swapping in a new motor.
Old Jan 22, 2005 | 08:45 AM
1999all_motoR_teg's Avatar
Default Re: (CleanShaven)
If you are sitting in the car put your arm lying face up on your right knee and follow that line to right under the dash/steering wheel. you will feel a square button there that is the button to reset it.
Old Jan 22, 2005 | 09:09 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanShaven &raquo;</TD></TR><TR><TD CLASS="quote">you guys are a bunch of dorks, i asked a simple question that you're all too "cool" to answer. </TD></TR></TABLE>
We answered your question. You must be new to the internet. Just click on the link:
LINK---&gt;Click Me&lt;---LINK
Old Jan 22, 2005 | 10:59 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanShaven &raquo;</TD></TR><TR><TD CLASS="quote">you guys are a bunch of dorks, i asked a simple question that you're all too "cool" to answer.</TD></TR></TABLE>
YOU'RE the dork. Half a dozen people point you to where YOU can find the answer - and you're too "cool" to click a link???
What an *******...
Old Jan 22, 2005 | 01:35 PM
Stein's Avatar
Default Re: (nsxtasy)
Mine went off recently and I looked in my manual, it goes off every 7500 miles IIRC. If your car doesn't need any service, just reset it.
Old Jan 22, 2005 | 02:12 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanShaven &raquo;</TD></TR><TR><TD CLASS="quote">you guys are a bunch of dorks, i asked a simple question that you're all too "cool" to answer. and half of you cant even spell correctly. Ive done all the work on my car including swapping in a new motor.</TD></TR></TABLE>
yet youre a fucktard and a troll....GTFO!
Old Jan 22, 2005 | 03:00 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (255.255.255.255)
Press el button under dash.
SEARCH OWNZ JOOOOOO
Old Jan 22, 2005 | 08:30 PM
BudMan's Avatar
Ok, let me get this straight - you swapped the new motor in, but can't determine on your own how to 'solve' this maintenance light problem? Perhaps that's why you had to swap out the original motor - no maintenance
Many of the answers posted here were to the point, and rather courteous. I think you should reconsider looking at the manual you used for your swap rather than pointing fingers. Try saying 'Thank You' to those who helped.
Old Jan 22, 2005 | 08:41 PM
Pure Adrenaline's Avatar
A newbie comes on the forum, asks a question, gets answers, but talks ****.
There's a simple solution to all of this -- get the **** out.
&lt;-- doesn't even have an R
Old Jan 22, 2005 | 08:54 PM
Bbasso's Avatar
Hit the road jack, I was nice and you **** on me. Don't let the door hit you on the way out
Old Jan 22, 2005 | 09:18 PM
1115R's Avatar
the (dorks) answered ur question so...
AMEN^^^
Old Jan 22, 2005 | 09:23 PM
By the way, isn't this in the owner's manual?
I don't know about the R since I don't own one, but for my TL-S, it's in the owner's manual.
He's too cool for the owner's manual, probably.
Old Jan 23, 2005 | 08:11 AM
Default Re: (Pure Adrenaline)
Actually Fucktards My car got Jacked. Thats why a new motor was put in. And what the hell is the point of having a forum? To answer and ask questions right? And talking all this craap in a forum is going to go nowhere so lets save eachother a hell of a lot of time.
Old Jan 23, 2005 | 08:37 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanShaven &raquo;</TD></TR><TR><TD CLASS="quote">Actually Fucktards My car got Jacked. Thats why a new motor was put in. And what the hell is the point of having a forum? To answer and ask questions right? And talking all this craap in a forum is going to go nowhere so lets save eachother a hell of a lot of time.</TD></TR></TABLE>
You're the one who started it, "fucktard". You're the one who was complaining AFTER people told you where you could find the answer to your question. People WERE answering your question and helping you. And for that, YOU started calling them "dorks" and talking crap.
If you don't like to see people talking crap, then why did YOU start talking crap yourself? And you're STILL talking crap, calling people "fucktards".
What an *******...
Old Jan 23, 2005 | 10:03 AM
Bbasso's Avatar
I guess you did not let the door hit you hard enough, try leaving again
Old Jan 23, 2005 | 10:16 AM
Chris F's Avatar
Default Re: (Bbasso)
I love you guys.
jamal-188
Sep 11, 2003 09:51 AM
vladd
15
Jul 17, 2003 12:52 PM
redteg1
Oct 14, 2002 04:40 AM
Integrity
Apr 6, 2002 05:26 AM
sackdz
Jun 23, 2001 09:36 AM
