timing belt bracket mount block attachment thing that i need <--what is the name and where can i
Old Jan 21, 2005 | 09:38 PM
bboylito's Avatar
Default timing belt bracket mount block attachment thing that i need <--what is the name and where can i
hey i have a 94 si hatch and i'm installing this 94 gsr, the gsr was in a ek so it has this bracket thing with only two holes, i was told that i need the one with three holes, where do i buy it and what is the name of the thing
thanks
Old Jan 21, 2005 | 10:47 PM
EK FLY's Avatar
Default Re: timing belt bracket mount block attachment thing that i need <--what is the name and where ca
u need one that has 2 bolt and 1 hole or just 2 bolt like the one on the trasmision
Old Jan 21, 2005 | 11:41 PM
drunknbass's Avatar
ig ot what you are looking for. the 2 studs that are about 1 inch apart and then theres a hole for a bolt to go down into and screw into the mount.
pm me for it
Old Jan 22, 2005 | 07:13 AM
moshi moshi's Avatar
its called a motor mount get it for a 94 gsr integraand get the bracket too thats the thing with 3 holes
Old Jan 22, 2005 | 12:18 PM
bboylito's Avatar
how much do they cost, i dont need the round mount with rubber on each side that attaches to the chassis, i already have it, i just need that part in the actual pic, and the 2 thick *** bolts that stick up through the holes
how much should i spend on that???????
Old Feb 25, 2005 | 07:05 AM
bboylito's Avatar
bump because i still need a name of that metal bracket thing that attaches to the block
i already have the mount, the part that i need has no rubber on it, it just has two long studs sticking out
What is that called SPECIFICALLY???????and how much should i spend on one????
thanks
Old Feb 25, 2005 | 07:23 AM
94eg!'s Avatar
#1 Super Guy
Loved
#8 = "Brkt, Engine Mount" $51.31 New @ AcuraAutomotiveParts.com
Old Feb 26, 2005 | 08:41 PM
bboylito's Avatar
thanks thats exactly it
kv72
Jun 17, 2012 12:31 AM
McDonagh
Sep 20, 2008 07:58 PM
PA MATT
Oct 23, 2006 12:51 PM
som3on3_10
Aug 13, 2004 12:12 AM
paulzy
May 16, 2003 12:05 AM
