P0505 Idle Control System Malfunction
Re: P0505 Idle Control System Malfunction (TurboEM1)
your iacv is either dirty or bad. Pull it off and clean it with some carb cleaner and put it back on. If that doesn't fix it than you'll have to buy one and they are fairly expensive.
Just in case you don't know the iacv is located on the back side of the intake manifold. It has 2, 12mm bolts, an electrical connector, and 2 hoses'. pull it off and clean it.
Re: P0505 Idle Control System Malfunction (civic-si-2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 »</TD></TR><TR><TD CLASS="quote">your iacv is either dirty or bad. Pull it off and clean it with some carb cleaner and put it back on. If that doesn't fix it than you'll have to buy one and they are fairly expensive.
Just in case you don't know the iacv is located on the back side of the intake manifold. It has 2, 12mm bolts, an electrical connector, and 2 hoses'. pull it off and clean it. </TD></TR></TABLE>
Thanks so much for the reply. I most likely can find it myself but are there any links with pics or a how to? Thanks again
