Can someone diagnose my engine problem? *VIDEO*
Old Jan 21, 2005 | 06:59 PM
lazynok's Avatar
Default Can someone diagnose my engine problem? *VIDEO*
http://www.nok7.com/noise.avi
in the video i'm adjusting the distributor and the TPS sensor to change the tone of the noise. If I had a light and voltmeter those would be set and i wouldnt be tinkering with them.. but since I don't and theyre not set they are great for changing the tone.
note. b18c1 swap into EH3.
possibilities,...
pinging.. since i have a LOT of 87 octane.. with a bottle of 108 octane booster. I think tomarrow would be a good day to buy some premium and pour it in.
knocking? I sure hope not... it is louder from under the car??
My uncle thinks its some exhaust leak... since i have no gasket on the 2 peice stock manifold seam and the manifold/cat isn't very tight...
or maybe something is just flapping...
or the valves.. oh god no not the valves!
someone help me =[ =[
note: it wasnt allways like this.. this started today. I don't even drive the car, its still on jackstands, I was messing with my throttle bodies (had strange TPS codes) and then the noise started)
Old Jan 21, 2005 | 07:11 PM
TeamNextGenChris's Avatar
Default Re: Can someone diagnose my engine problem? *VIDEO* (lazynok)
you need to fix your obvious problems first-exhaust leak,TPS and timing-before trying to figure out what's wrong with it.
hard to tell from the video,since it distorts the sound so much.check valve lash,check that crank pulley isn't rubbing the timing belt cover.sound kinda sounds like an exhaust leak anyway.
car will idle without knocking on 87 octane.
Chris
b18bcivic's Avatar
sounds like something rubbing...did you check the clutch cover plate???flywheel could be hitting it.?
Old Jan 21, 2005 | 07:17 PM
lazynok's Avatar
Default Re: Can someone diagnose my engine problem? *VIDEO* (b18bcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcivic &raquo;</TD></TR><TR><TD CLASS="quote">sounds like something rubbing...did you check the clutch cover plate???flywheel could be hitting it.?</TD></TR></TABLE>
thats funny.. cause i am using a D16Y7 clutch cover plate only because I dont have a b18c1 version.
so it does NOT fit at all... but it serves its purpose.. but I dont tihnk its hitting.. i'll check that too. don't know why that would change with timing/tps though. thanks i'll check in daylight
Old Jan 22, 2005 | 03:25 PM
lazynok's Avatar
someone else watch my video and give input =]
Old Jan 22, 2005 | 04:09 PM
cardr's Avatar
It does not sound good! hard to tell but, u definately have an internal engine problem. When u get closer to the engine to "adjust" the distributor you can hear the engine pinging! Most likely because u advanced the hell out of the timing but even before then u can hear the engine knocking. Get some equipment fast and adjust that car the right way.
Old Jan 24, 2005 | 05:22 PM
lazynok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcivic &raquo;</TD></TR><TR><TD CLASS="quote">did you check the clutch cover plate???flywheel could be hitting it.?</TD></TR></TABLE>
DING DING DING winner.
thanks a lot b18bcivic and everyone for your help!! fixed now. useless bump =]
Sqni
Mar 7, 2019 01:39 PM
japscrap
Jan 31, 2009 12:55 PM
zeplin
16
Dec 31, 2008 07:22 AM
lazynok
Jan 21, 2005 07:10 PM
ITR0950
May 11, 2004 11:20 PM
