Differences in B-Series Oil Pumps?
Old Jan 21, 2005 | 04:53 PM
d.str0y's Avatar
Default Differences in B-Series Oil Pumps?
Compare an ITR oil pump and an LS oil pump. What physically makes the VTEC oil pumps better than the non-VTEC oil pumps? Just the spring thats on the inside that controls oil flow? Or is there something else?
Old Jan 21, 2005 | 05:16 PM
drdisco69's Avatar
Default Re: Differences in B-Series Oil Pumps? (onezexycrx)
The VTEC oil pumps are the same. There are only 2 types of B series oil pumps, OBD2 and non OBD2. The OBD2 have a mount for the crank fluctuation sensor, that is the only difference.
The oil pressure is not determined by the pump, but the pressure relief spring in the block, as you mentioned.
Old Jan 21, 2005 | 06:22 PM
havok hybrid's Avatar
Default Re: Differences in B-Series Oil Pumps? (drdisco69)
there is no spring in the block..
there is a washer/shimm in the bottom of the pump... that sets the pressure....
on has the washer.. one doesnt..
Old Jan 22, 2005 | 03:32 AM
d.str0y's Avatar
I thought the spring was in the pump itself. So basically what i'm asking is, could I use the spring from an itr pump in an ls pump to make it function like an itr pump?
Old Jan 22, 2005 | 05:00 AM
slomofo's Avatar
GDD Member
Here is your question:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onezexycrx &raquo;</TD></TR><TR><TD CLASS="quote">I thought the spring was in the pump itself. So basically what i'm asking is, could I use the spring from an itr pump in an ls pump to make it function like an itr pump?</TD></TR></TABLE>
Here is your answer:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The VTEC oil pumps are the same. There are only 2 types of B series oil pumps, OBD2 and non OBD2. The OBD2 have a mount for the crank fluctuation sensor, that is the only difference.
The oil pressure is not determined by the pump, but the pressure relief spring in the block, as you mentioned.</TD></TR></TABLE>
VTEC/Non-VTEC has the same pump.
Old Jan 22, 2005 | 06:39 AM
d.str0y's Avatar
but as mentioned in the above post, the spring is not in the block. it is in the pump iteself. So my question is "Are the pressure springs in B-Series oil pumps interchangeable?"
Old Jan 22, 2005 | 11:58 AM
civickiller's Avatar
Default Re: (onezexycrx)
so then when all these people are putting vtec oil pumps on there ls block, its for nothing ?
Old Jan 22, 2005 | 12:52 PM
d.str0y's Avatar
exactly why I am asking, because you can buy just the pressure spring separately.
Old Jan 23, 2005 | 04:55 AM
d.str0y's Avatar
I guess i'll be the first to try...
I cant see why it would not work.
But thats is why I asked to see if anyone else had similar thoughts.
Old Jan 23, 2005 | 10:58 AM
let us know how it goes. do you have a oil pressure ot measure the change ?
Old Jan 23, 2005 | 12:29 PM
d.str0y's Avatar
I will let everyone know the results. Although, It may not be for a while.
Old Jan 23, 2005 | 02:57 PM
d.str0y's Avatar
The part numbers for the Relief Valve and Relief Valve Spring are the same for all B-Series oil pumps. So what makes a VTEC oil pump different from a non-VTEC one?
Old Jan 23, 2005 | 04:03 PM
YES that is all you have to do.. is swap the washer... witch increases the oil pressure... from 60 to 90 ..
Old Jan 24, 2005 | 08:20 AM
d.str0y's Avatar
So there's a washer in the oil pump that regulates flow?
Old Jan 24, 2005 | 05:36 PM
NJIN BUILDR's Avatar
The washer is a shim that preloads the spring.
Glenn
aavtec
14
Mar 25, 2013 12:23 AM
Circuit Star-29
May 5, 2006 09:40 PM
URNVS
Dec 8, 2004 08:50 AM
-KangaRod-
Mar 22, 2004 02:52 PM
SoloSol
Aug 7, 2003 01:35 PM
