timing belt question
Old Jan 21, 2005 | 10:14 AM
hatch_attack's Avatar
Default timing belt question
if the timing belt isnt put on with everything lined up correctly, could it effect where the marks on the crank pulley show when you shoot it with the timing light?
Old Jan 21, 2005 | 10:30 AM
JimBlake's Avatar
Default Re: timing belt question (theswarm)
Sure it will. It'll also affect when the valves open. So fix it first, then re-adjust your spark timing.
Old Jan 21, 2005 | 10:43 AM
Default Re: timing belt question (JimBlake)
yea cuz right now when i shoot the crank pulley with the timing light, it looks like its running extremely advanced. but it feels like its running retarded because it bogs down a lot and dies on me sometimes, like its running rich.
Old Jan 21, 2005 | 11:21 AM
b18bturbo's Avatar
first off make sure your marks all line up the crank pulley and then with the cams. After that if everythign lines up then you shuold be good to adjust the timing on the distrib right now you can damage thigns if you are not careful
Old Jan 26, 2005 | 03:38 PM
Default Re: timing belt question (b18bturbo)
ok so i got the everything lined up now, but i cant get the timing past like 9 degrees. distributors advanced all the way. when i drive the car, if i hit the gas kinda hard, the car will idle very rough or just die out. if i turn it off, restart it, and just push the gas gradually it drives ok. and in the high rpms, it bogs down if i give it too much gas. i dont see why i cant pull more timing out of it.
Old Jan 26, 2005 | 07:20 PM
anybody? id really like to get my timing problem solved as soon as possible.
Old Jan 27, 2005 | 03:56 AM
JimBlake's Avatar
What kind of car? Maybe something with a strange procedure for checking timing?
Before checking timing, did you get the engine warmed up & jumper the SCS connector?
Are you possibly using a timing light with an advance dial, then ALSO trying to adjust to the 16btdc marks?
Last (not very likely)... Is it possible the crank pulley is messed up? Take it off (easy for me to say, huh?) Check the mark on the timing belt sprocket against the mark on the oil pump. Or just stick something in a sparkplug hole to verify that it's really TDC...
Old Jan 28, 2005 | 02:03 PM
its a 91 integra. ls/vtec.
how can i tell if i jumped the connector right? i pushed the paper clip way in there and nothing changed when i tried adjusting the timing. still at like 9 degrees. the timing light im using doesnt have any dials. its just fixed.
Old Jan 29, 2005 | 01:52 PM
bump?
Old Jan 30, 2005 | 01:01 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theswarm &raquo;</TD></TR><TR><TD CLASS="quote">its a 91 integra. ls/vtec.
how can i tell if i jumped the connector right?</TD></TR></TABLE>On my '95, when you have it jumpered correctly, the CEL stays on solid. I don't know if '91 is the same way?
unisonicz
Engine Management and Tuning
Feb 28, 2016 01:46 PM
Bob_760
Jan 30, 2008 02:48 PM
Running925
Oct 22, 2007 10:13 AM
sivik2nr
May 29, 2003 09:30 PM
