Timing marks out of range?
Old Oct 16, 2007 | 07:41 PM
Running925's Avatar
Default Timing marks out of range?
hey guys, just a little confused on this here. I just finished building a GSR engine for someone & i got it running on his new injectors. After that before we decided to take it out for some street tuning we threw the timing light on it. Now mind you, the car seems to run fine & drive around the block with no problems or hesitations but the timing marks just don't line up when using the timing light. I just can't turn the dizzy far enough to make it come within range.
Ideas?
(crank spine off one tooth yet happens to run right for some reason? idk) ??
Old Oct 16, 2007 | 07:43 PM
93turbo16's Avatar
It has to be off a tooth or so somewhere. Re-check the mechanical timing is the obvious thing to do.
Old Oct 16, 2007 | 08:02 PM
Running925's Avatar
Default Re: (93turbo16)
thats what i was leaning twords.. its just odd that it doesn't act weird while it's running or driving. (haven't really beat on it yet, glad we didn't!)
Old Oct 16, 2007 | 08:39 PM
CoreyR's Avatar
Default Re: (Running925)
the mechanical timing can be off a tooth or so and not affect driveability.
Old Oct 17, 2007 | 05:22 AM
Running925's Avatar
Default Re: (CoreyR)
thanks, i'll be re-setting the timing belt tonight after work
Old Oct 17, 2007 | 11:53 AM
boosted k20's Avatar
also make sure u r using an OEM crank pulley. i seen crank pulleys that "look" like stock not have n e timing markings. also make sure u put in the woodruff key into the crank/crankpulley
Old Oct 20, 2007 | 03:46 PM
Running925's Avatar
Ok, i've fixed the timing & it's correct according to the timing light. But now the car will not maintaine temp. it over heats every time you start it & let it warm up. IDK what the hell it's all about but it doesn't make any since, i've gone thought everything, i've checked the fan, it works, i've changed the thermostat, i've changed the head gasket, i've eliminated the heater core out of the loop, i've changed every coolant hose in the entire system. What the hell! ???? any suggestions would be greatly appreciated.
thanks for any help that someone can give me.
Old Oct 20, 2007 | 04:23 PM
boostedh22lude1's Avatar
check your grounds if you have a ground off sometimes the temp gauge will give false readings, other than that if your fan is working a t stat is opening and radiator isnt cloged its your water pump, theres not much to a cooling system so do all ur checks
Old Oct 20, 2007 | 04:29 PM
Running925's Avatar
Default Re: (boostedh22lude1)
this is a freshly built motor with a brand new water pump that was working fine last week, also new dual core aluminum radiator.
Old Oct 20, 2007 | 06:17 PM
xenocron's Avatar
Air bubbles in the system?
Cars are hard pressed to overheat at idle...if the fan is working.
Old Oct 21, 2007 | 10:00 AM
Running925's Avatar
Default Re: (xenocron)
this thing doesn't have a bleeder s i just left the radiator cap off for 20min.
you can tell when the thermostat opens coz the coolant starts to move. Hell i've even let it sit there with out the thermostat in it & it still over heats... it's really frustrating!
Old Oct 21, 2007 | 01:53 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 &raquo;</TD></TR><TR><TD CLASS="quote">this thing doesn't have a bleeder s i just left the radiator cap off for 20min.
you can tell when the thermostat opens coz the coolant starts to move. Hell i've even let it sit there with out the thermostat in it & it still over heats... it's really frustrating!</TD></TR></TABLE>
Is it really overheating? Maybe the gauge or sender is off? How long does it take to show hot when starting it cold and letting it idle? What is the coolant temp at the radiator fill neck? Does the fan/s come on?
Old Oct 21, 2007 | 06:54 PM
Running925's Avatar
Default Re: (Chiovnidca)
it's definatly over heating, i had my laptop connected to the ecu to confirm it, the boiling coolant is also a major sign!
Old Oct 22, 2007 | 03:08 AM
Chiovnidca's Avatar
Have you checked it for a blown headgasket?
Old Oct 22, 2007 | 05:36 AM
Running925's Avatar
yep it's fine...
Old Oct 22, 2007 | 06:49 AM
xsi-t's Avatar
all i can say is do a leakdown test on it..
Old Oct 22, 2007 | 09:32 AM
Running925's Avatar
Default SOLVED
SOLVED
radiator was mounted 4inches lower than stock location due to the kids supid manifold.
Radiator was relocated to a higher location & car idles without overheating!
Test drive will happen after work tonight, i'm glad to have this thing close to done so i can have some space back in my garage!
Old Oct 22, 2007 | 10:13 AM
xsi-t's Avatar
Default Re: SOLVED (Running925)
damn 4 inches i would have loved to see how low that sat. congrats on the fix
1mistashank
May 29, 2009 08:17 PM
JDMtype Eg6
Sep 3, 2008 05:14 AM
sageuvagony
Apr 5, 2007 05:47 AM
hatch_attack
Jan 30, 2005 01:01 PM
wantmorepower
Apr 16, 2003 09:52 PM
