why is my car boosting passed boost cut?
Old Jan 20, 2005 | 09:01 PM
budget's Avatar
Default why is my car boosting passed boost cut?
my boost cut is set a 1bar and ive been driving on it for a while now so i know how hard it pulls, but lately (hot or cold) its been pulling much harder than usual, i was lucky and got one of the non defected autometer boost gauge, i did a couple of third gear pulls and it was reading 17-18psi?? weird thing is im running strait wastegate with a .9bar spring
only thing i can think of is my dp might be a little loose, my freind broke my vband flange, but still its on there pretty snugly.
any help would be great
Old Jan 21, 2005 | 08:47 AM
richeybrooks's Avatar
Default Re: why is my car boosting passed boost cut? (ratboy)
it would be helpful to know engine setup and fuel managment.
it you car is stock it wont last much longer with 17psi on a 3rd geer pull.
Old Jan 21, 2005 | 08:56 AM
Finland's Avatar
fyi, the term 'boost cut' pertains to the ECU and its pressure sensor - sensing pressure that is higher than the setpoint, it then pulls fuel and, or spark. The wastegate has nothing to do with boost cut.
Old Jan 21, 2005 | 09:42 AM
raene's Avatar
Are you using a stock map sensor?
Old Jan 22, 2005 | 06:12 AM
budget's Avatar
Default Re: why is my car boosting passed boost cut? (raene)
nope 3 bar
Old Jun 10, 2007 | 11:33 PM
boomersz's Avatar
Default Re: why is my car boosting passed boost cut? (budget)
im having the same problems too.
Old Jun 10, 2007 | 11:35 PM
SOHC_MShue's Avatar
datalog your map sensor readings during a run and get back to us
KevinEF7
Oct 7, 2013 10:43 PM
swappedcx
Aug 16, 2006 03:04 PM
Hyper_Racer23
Mar 27, 2003 07:00 PM
FUP23
Sep 30, 2002 09:15 PM
