electric supercharger????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benbuilt4u »</TD></TR><TR><TD CLASS="quote">use the search
just so YOU know u will be docked points for saying that, and to the original poster, they are a gimmick and dont do anything
</TD></TR></TABLE>just so YOU know u will be docked points for saying that, and to the original poster, they are a gimmick and dont do anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
just so YOU know u will be docked points for saying that, and to the original poster, they are a gimmick and dont do anything</TD></TR></TABLE>
Shut up.......
To speedy94ex...search. i think i even seen a write up on someone getting one of these and using it.....just search. type in the same as the title of your post.
Shut up.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 »</TD></TR><TR><TD CLASS="quote">
Shut up.......
To speedy94ex...search. i think i even seen a write up on someone getting one of these and using it.....just search. type in the same as the title of your post. </TD></TR></TABLE>
maybe you're unfamiliar with the thread and the update to the rules...
https://honda-tech.com/zerothread?id=1118700
so maybe you should shut up and think before you speak
Shut up.......
The electric supercharger is bullshit. They even go so far as to cause vacuum at high end and rob HP by disrupting airflow. Think about it: if those could do the job of $2000 turbo kits, would said kits still be in use?
i think i read this on SHO where a b16 had it, the fan broke off and spun itself into little pieces of debris which were then sucked right into the IM and well...i think you know the rest then...8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jethawk »</TD></TR><TR><TD CLASS="quote">another gimick... dont even consider buying one</TD></TR></TABLE>
worth repeating
worth repeating
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">
worth repeating</TD></TR></TABLE>
http://www.homemadeturbo.com did a review on it, which is ehere I got my info. They said the only real use for it was to play baseball with.
