hx motors
Old Jan 20, 2005 | 07:49 PM
Champ White EJ8's Avatar
Default hx motors
do ex parts fit on this motor, like headers or intake manifold? stuck with an hx motor in my 98 coupe until gsr is done
Old Jan 20, 2005 | 07:52 PM
eK9aT10pSi's Avatar
Default Re: hx motors (Champ Ek9)
the headers will. cant remember about the IM
Old Jan 20, 2005 | 08:01 PM
murmur9's Avatar
Default Re: hx motors (eK9aT10pSi)
Yea...headers and IM should bolt up fine. umm...if you use OEM IM's and just mix and match.....i believe 00+ civics IM has an aditional vacumehole that you should use jb weld to cover up. do so me searching. most parts on D series motors and interchangeable
Old Jan 20, 2005 | 08:49 PM
blackeg's Avatar
Default Re: hx motors (murmur9)
exhaust manifold will work, there might be some small issues with the egr on the intake manifolds. cams are not compatible
nightscream
Jan 13, 2011 04:10 AM
bibong
10
Oct 11, 2006 05:53 AM
wicivic
Honda Civic (2001 - 2005)
Jun 22, 2006 05:43 PM
civicmatt
Nov 28, 2002 03:36 PM
acme
24
May 20, 2002 02:43 PM
