What is the best thing to do to a B16a?
Old Jan 20, 2005 | 07:10 PM
RedlineboyzCRX's Avatar
Default What is the best thing to do to a B16a?
I can't think of what else to do to my car, for more HP. Here is the link http://www.freewebs.com/team_redline/ebassride.htm Thanx for the input
Old Jan 20, 2005 | 07:13 PM
Hybrid96EK's Avatar
Default Re: What is the best thing to do to a B16a? (RedlineboyzCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlineboyzCRX &raquo;</TD></TR><TR><TD CLASS="quote">I can't think of what else to do to my car, for more HP. Here is the link http://www.freewebs.com/team_redline/ebassride.htm Thanx for the input</TD></TR></TABLE>
Get some better cams. Get a better header. Huck the retarded Mugen chip. Put it on a dyno. Get some pistons and raise the compression. Balance the bottom end. Get a lighter flywheel. Get an R intake mani. Do you really need us to point these things out?
Old Jan 20, 2005 | 07:29 PM
PHOBIA's Avatar
turbo, small amounts off boost will work wonders.that and a new paint job,other than that it would be complete IMO
Old Jan 20, 2005 | 07:36 PM
EP3_05's Avatar
Default Re: What is the best thing to do to a B16a? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Get some better cams. Get a better header. Huck the retarded Mugen chip. Put it on a dyno. Get some pistons and raise the compression. Balance the bottom end. Get a lighter flywheel. Get an R intake mani. Do you really need us to point these things out?</TD></TR></TABLE>
Exactly...or go with a turbocharger and a small amount of boost...7-10psi should be good as long as the tune is good. Also maybe add some wheels, bodywork, and paint to your list of things to do to your car...Just my opinion but you asked for it...
Old Jan 20, 2005 | 07:59 PM
doublethink's Avatar
drive it.
Old Jan 20, 2005 | 08:22 PM
Stefndogg's Avatar
Default Re: What is the best thing to do to a B16a? (doublethink)
get rid of the bodykit...get some rims...than start throwing money at making it faster...im sure it would be quite a bit faster if it didnt have those dummys on the front...pick up a set of decent tires...nice car tho
Old Jan 20, 2005 | 08:25 PM
Smokinsax's Avatar
The Boot
Default Re: (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">turbo, small amounts off boost will work wonders.that and a new paint job,other than that it would be complete IMO</TD></TR></TABLE>
Old Jan 20, 2005 | 08:30 PM
stockbee's Avatar
the question you need to ask yourself before you delve into anything deeper, is what do you want this car's purpose to be? just something to street all the time, or do you foresee it accomplishing other feats as well.
like they said, go with cams and do some more NA work, seems like that's the way your headig inthe first place.
good luck with it. p.s. lose the body kit, and you car might be a little faster, jk.
Old Jan 21, 2005 | 04:54 AM
Ruthless671's Avatar
Default Re: (stockbee)
spray, spray
Old Jan 21, 2005 | 06:15 AM
Mag00n's Avatar
You have a nice basic all-motor setup there. If I was you Id put some wheels on that car for god's sake. Like flat black slips or whatever you like. As far as the b16, id get pistons next if your bent on going faster. Youll need a good tune though with pistons.
rustydusty1717
59
Dec 27, 2007 05:24 AM
PostSRT
Sep 18, 2007 01:34 PM
JDMpianoguy
May 4, 2004 01:25 PM
7rrivera7
Sep 9, 2003 11:01 AM
sparq
Apr 19, 2003 04:25 PM
