how to install a rpm guage
Hey fellas, it has come time again to ask for your help. I just bought a autometer rpm guage. I not sure where am i gonna hoock up the green wire. I use the red wire in one of the open fuse terminal, hook up the white wire up, ground the black, but not sure where the green one goes. Also do i clip the brown,yellow wires because its not a v-8,v-6. Thanks!
From: Toronto, Ontario, Canada, North America,, Earth
I'm guessing here, because I've never installed one, but maybe the green connects to the harness that connects to your Cluster?
just try the search i typed in tach and got a good amount of results for example look at these:
https://honda-tech.com/zerothread?id=1121178
https://honda-tech.com/zerothread?id=1119679
green wire from the autometer go to the tach signal which is blue wire on the driver side shock tower if you car is an eg, or you can hook it at the ecu.
Modified by 2lua at 8:01 PM 1/20/2005
or if u want, behind the gauge cluster, in the wire harness taht plugs into the cluster, their should be a blue wire (tach) all 92-95 civic are prewired for a tach, and the clock
EG type GTR
Jul 20, 2006 11:38 AM
