need advice to see if everything is normal
well i have just recently installed a set of solid poly. motor mounts on my 00 hatch and got rid of that liquid filled POS. and yes i feel a lot more vibrations comeing from the engine, however at 5400RPM when VTEC comes on the shifter feels a LOT more vibration than under VTEC is this normal? or is my motor on the skitz?
its actually normal cause when the stock mounts where in your car they would absorb all the vibration now that you have the poly's your engine and drive train will absorb it and thats when you feel the vibration in the shifter so nothing to worry about
