f23a4 engine mounts
Old May 25, 2010 | 10:22 AM
spike32's Avatar
Default f23a4 engine mounts
00 Accord 2.3L VTEC ULEV w/ standard trans.
I have a clunk sound when shifting gears and I need new engine mounts.
How many engine+transmission mounts do I need.
Also what brand is recommended? BECK/ARNLEY, ANCHOR... or do people strongly recommend Honda OEM?
Thanks.
Old May 25, 2010 | 10:48 AM
hondamark35's Avatar
Default Re: f23a4 engine mounts
Originally Posted by spike32
How many engine+transmission mounts do I need[?]
you tell us.. how many are broken? or do you want to just replace all of them? if that's the case, four.
i wouldn't expect a significant gap in quality between after market replacements and OE honda mounts. but, maybe someone who has tried one of those brands can shed some light..
Old May 25, 2010 | 07:36 PM
spike32's Avatar
f23a4 2.3L VTEC ULEV engine w/manuel transmission
rockauto carries ANCHOR brand for all 4 mounts, BECK/ARNLEY only has the front and rear.
I read on this forum about using inserts, but I cannot locate any for my car.
Old May 26, 2010 | 03:02 PM
AFAccord's Avatar
LIKELY... it's on the front or rear (or both) mount(s) that are broken. They are the ones that suspend the engine's torque movement.
If you want inserts, the 5th gen Accord's inserts will work...
http://www.tasauto.com/Product/Detai...31907&d=91&p=2
If your mounts are busted though, I would advise you to replace the broken mounts and THEN install the inserts.
Old May 27, 2010 | 12:05 PM
02 accord's Avatar
Replace all 4 due to the age of the car. I suggest you go with autozone ones with a lifetime warranty. If you break them again, just go to the store and get new ones.
I replaced my front and rear mounts, thinking that would solve my harsh clutch engagement problems. After also replacing the 2 side mounts (all 4 new), it was a night and day difference.
Old Jun 5, 2010 | 10:44 PM
spike32's Avatar
Front and Rear I replaced with OEM for $100 combined. Right and Left I replaced with aftermarket. If the side ones go bad quickly, I might get Honda OEM. But each side mount is over $100 OEM.
It is like night and day, but I still have clunk when going into 1st and sometimes when changing gears, but otherwise the shifting more smoother and much stiffer.
Sometimes when cruising in a parking lot in 2nd, At a certain point where the engine pushes the wheels, and then the wheels push the engine, I hear a clunk clunk clunk. What could that be if its not the mounts?
Do I need to change part #4 or was the mount (#3) enough? #4 just floats there on top of the mount, but does it contribute anything?
saintbhts
Sep 12, 2014 08:09 AM
sr20paisa
Welding / Fabrication
Jan 20, 2014 05:06 PM
GoLowDrew
Jun 25, 2013 08:34 AM
EG6Boy702
33
Apr 27, 2009 03:55 PM
sixtodc2
Jul 13, 2007 12:43 PM
