Solid inserts for Hasport mounts
Old Dec 7, 2007 | 11:42 AM
brian g's Avatar
Default Solid inserts for Hasport mounts
For those of you using the Long shifter or G Force shifter, Hasport now has solid inserts available. The inserts can be ordered with new mounts or retrofitted to Hasport mounts you already own.
For more information you can contact us at sales@hasport.com or post your questions here.
brian g
Modified by brian g at 11:19 PM 12/7/2007
Old Dec 7, 2007 | 11:54 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Solid inserts for Hasport mounts (brian g)
brian g, stop trying full a need.
Old Dec 7, 2007 | 12:22 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Solid inserts for Hasport mounts (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">brian g, stop trying full a need. </TD></TR></TABLE>
What did you say?
Old Dec 7, 2007 | 12:40 PM
InDub's Avatar
Default Re: Solid inserts for Hasport mounts (rota92)
got these going in right now
Old Dec 7, 2007 | 12:43 PM
DaveF's Avatar
Default Re: Solid inserts for Hasport mounts (InDub)
are those aluminum or steel ?
Old Dec 7, 2007 | 12:45 PM
InDub's Avatar
Default Re: Solid inserts for Hasport mounts (DaveF)
I believe they are aluminum and thats the only problem i forsee in the future is no steel sleeve in the center, but maybe I am wrong.
Im sure Brian will answer
Old Dec 7, 2007 | 02:18 PM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InDub &raquo;</TD></TR><TR><TD CLASS="quote">I believe they are aluminum and thats the only problem i forsee in the future is no steel sleeve in the center, but maybe I am wrong.
Im sure Brian will answer</TD></TR></TABLE>
Don't torque the mount bolts past 250 ft/lbs and lack of a steel sleeve won't be a problem.
brian g
Old Dec 7, 2007 | 03:21 PM
WHTZ's Avatar
How much are the sleeves going for?
Old Dec 7, 2007 | 05:08 PM
brian g's Avatar
Default Re: Solid inserts for Hasport mounts (WHTZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTZ &raquo;</TD></TR><TR><TD CLASS="quote">How much are the sleeves going for?</TD></TR></TABLE>
PM For pricing
brian g
Old Dec 7, 2007 | 05:24 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Brian Check your PM's
Old Dec 7, 2007 | 06:58 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">
PM For pricing
brian g</TD></TR></TABLE>
No sales antics in the drag racing section Better delete that before the post gets locked
Old Dec 7, 2007 | 07:03 PM
SpeedDreamz.com's Avatar
Default Re: Solid inserts for Hasport mounts (BoostedJeff)
thems purdy.
Old Dec 7, 2007 | 07:54 PM
wickedEG's Avatar
Old Dec 7, 2007 | 08:08 PM
Fitti's Avatar
Default Re: Solid inserts for Hasport mounts (wickedEG)
These inserts look really nice
Old Dec 8, 2007 | 05:02 AM
tepid1's Avatar
Default Re: Solid inserts for Hasport mounts (Fitti)
It's good to see that these are now finally available to the public.
for Hasport
Do you need to press them in Brian?
Old Dec 9, 2007 | 04:48 AM
PremierS372's Avatar
Default Re: Solid inserts for Hasport mounts (tepid1)
Sweet, finally
Old Dec 9, 2007 | 06:53 PM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">
Do you need to press them in Brian?</TD></TR></TABLE>
The inside of the mount gets machined and the bushing is inserted. It can be press or slip. It depends on whether you want it to be permanent or you want to change them back to urethane to drive on the street.
brian g
Old Dec 9, 2007 | 07:31 PM
Antilag's Avatar
I pmed you Brian. I need some asap!
Old Dec 9, 2007 | 10:10 PM
paulzy's Avatar
so the mounts need to be machined to fit the new bushings?
Old Dec 10, 2007 | 07:22 AM
Antilag's Avatar
Default Re: (paulzy)
I just talked to them. You need to send your mounts in, and they will install them for you. Good price including install though.
Old Dec 10, 2007 | 12:24 PM
tepid1's Avatar
Brian.... you sir, are the man!
Thanks a million. Hasport FTW
Old Dec 10, 2007 | 05:19 PM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">so the mounts need to be machined to fit the new bushings?</TD></TR></TABLE>
Correct.
brian g
Old Dec 11, 2007 | 09:26 AM
ef4dr's Avatar
Default Re: (brian g)
pm'd
D16SohcVtec
Aug 12, 2008 08:03 AM
1fastEK9
19
Jan 31, 2007 11:20 AM
CRseXy
Oct 10, 2004 11:31 PM
racingant
10
Mar 13, 2004 07:17 PM
dan89crxsi
Oct 3, 2003 09:08 PM
