DelSol rear license plate panel.. help taking it off pls..
From behind (inside the trunk) use vise grips to take them off, replace with a standard nut and discard those circle shaped nuts!
Do Not Use a Punch...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR »</TD></TR><TR><TD CLASS="quote">From behind (inside the trunk) use vise grips to take them off, replace with a standard nut and discard those circle shaped nuts!
thought so.. just wanted to make sure thank..
any other bolts nuts that i need to take off to get the panel off ??
</TD></TR></TABLE>thought so.. just wanted to make sure thank..
Open up the trunk remove the plastic panel towards you. There are some bolts you have to take out from inside if you want the whole rear metal license plate off. Not sure if thats what you want to do but thats how u would do it if you wanted to do it... Nice tongue twister huh?
