Remove the Emblems
Old Nov 11, 2005 | 01:19 PM
Elbowpunk's Avatar
Default Remove the Emblems
I really want to remove the A and the LS emblems... i kno how to get them off... like use a hair dryer to lossen the glue and then slide a credit card threw it...
THEN
how do i fill in the holes??? Use bondo ?? any help would be tight
Old Nov 11, 2005 | 01:28 PM
thomah's Avatar
Default Re: Remove the Emblems (Elbowpunk)
try use floss...
Old Nov 11, 2005 | 01:35 PM
SLH356's Avatar
Default Re: Remove the Emblems (thomah)
The way you covered up your plate it looks like it says buttsex. . Floss works well to get them off, the ideal way to cover up the holes would be to weld them shut.
mx524's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomah &raquo;</TD></TR><TR><TD CLASS="quote">try use floss...</TD></TR></TABLE>
he just said that he KNOWS how to take them off dude. can you read?
you can do a few things actually...most will require re-painting the area. you can use fiberglass and bondo to fill the hole (this is how i have filled spoiler holes in a trunk) or you can weld in new metal over the holes.
Old Nov 11, 2005 | 01:49 PM
Platinum Playa's Avatar
why not keep them reason being. once you fill with bondo and re paint the paint wont match.
Old Nov 11, 2005 | 02:02 PM
thomah's Avatar
Default Re: (Platinum Playa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx524 &raquo;</TD></TR><TR><TD CLASS="quote">
you can do a few things actually...most will require re-painting the area. you can use fiberglass and bondo to fill the hole (this is how i have filled spoiler holes in a trunk) or you can weld in new metal over the holes.</TD></TR></TABLE>
so what? I was just telling him another way that might easier than using a hair dryer...wth is your problem...
Old Nov 11, 2005 | 02:20 PM
jessec's Avatar
i used fiberglass ion the inside, bondo'd over the holes, and used colour-match paint for now until i get all my body work done and get a new paint job
though i'm removing that, and i've got soe aluminum sheet metal + jb weld, and gonna replace the fiberglass with that, then use aluminum filler to cover the whole instead of bondo..
probably won't be until next spring when it's warmer, so i won't know how well it works until then
of course, ideally, you would want it welded properly.. but to me, that costs too much
Old Nov 11, 2005 | 02:33 PM
Hondacrx628's Avatar
Honda emblems my friend..
Old Nov 11, 2005 | 08:47 PM
Elbowpunk's Avatar
Default Re: (Hondacrx628)
so bondo it ??? and primer then paint then clear coats ???
Old Nov 12, 2005 | 07:09 AM
maggsgsr's Avatar
Default Re: (Elbowpunk)
Ditch the 3 stars They we cool about 12-13 years ago.
gutted-dx
Oct 1, 2005 01:44 PM
Honda_18
25
Dec 5, 2004 02:38 PM
rice a roni
Sep 7, 2004 09:57 AM
null.
Aug 25, 2004 06:21 PM
Mason Dixon
Dec 8, 2003 11:08 AM
