Where does this wire go?
Old Jan 20, 2005 | 03:46 PM
98civic94gsr's Avatar
Default Where does this wire go?
I have a 98 civic hx and a 94 gsr motor in it.... About 8 inches off the firewall on the main wire harness is a thick white wire with just an eyelit at the end... Where does this go?
Thanks
98civic94gsr
Old Jan 20, 2005 | 03:49 PM
DelSolDon's Avatar
Default Re: Where does this wire go? (98civic94gsr)
it goes to the top of your alternator.
Old Jan 20, 2005 | 04:56 PM
Default Re: Where does this wire go? (DelSolDon)
Boy I really don't think it will reach all the way to my alternator... I don't think its that long... Could it possibly go somewhere else? I think I have 2 different wires already going to my alternator. The eyelit is very small like maybe a quarter inch diameter....
Thanks
98civic94gsr
Old Jan 20, 2005 | 04:57 PM
Andres-eh2's Avatar
post a pic!
Old Jan 21, 2005 | 06:15 AM
Default Re: (Andres-eh2)
bump
Old Jan 21, 2005 | 07:54 AM
spoonek9's Avatar
Default Re: (98civic94gsr)
Not sure, but check your under the hood fuse box. I pretty sure there should be a white wire in there.
Old Jan 21, 2005 | 07:55 AM
evilsolb16's Avatar
Default Re: (spoonek9)
the fuse box on pass side of engine bay
Old Jan 23, 2005 | 07:38 AM
DelSolDon's Avatar
Default Re: (evilsolb16)
if it is a jdm motor, then you will have to extend, or just replace (suggested) the wire. one end goes to the top of the alternator and the other end goes to your fuse box. i think it is 6awg wire you need. apperntly you have to do this with jdm motors cause the fuse box and batt. are on the opposite side as usdm.
Old Jan 23, 2005 | 12:35 PM
hatchi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">Not sure, but check your under the hood fuse box. I pretty sure there should be a white wire in there. </TD></TR></TABLE>
this is where it goes there are 2 spaces there where it will screw in
Old Jan 23, 2005 | 07:16 PM
Default Re: (hatchi)
Well it went to the fuse box. Thanks guys for the help....
Swap is done and running after a long damn time. Now all I gotta do is replace the stripped oil plug and she's ready to roll.
Thanks
98civic94gsr
jdmturboitr
Apr 12, 2012 05:39 AM
blackccoupe
Audio / Security / Video
14
Mar 28, 2008 03:36 PM
(760)doogie
Jul 9, 2007 04:20 PM
russianswty
Dec 22, 2006 06:57 PM
HondaHemi
Nov 27, 2006 04:38 PM
