Kinda weird
Old Jan 20, 2005 | 02:52 PM
siblueg's Avatar
Default Kinda weird
Ok to start off my set up is a 97 itr swap running on a chipped p28, thats really the only modds. Some times when it's cold it will start to smoke white only when the engine is slowing down the vehicle, for example say your cruising along at 3500rpm and take your foot off the gas for maybe 2 seconds and then continue your normal driving by putting your foot on the gas it starts to smoke for a couple of seconds. i have changed the pcv vavle and hose i do not know what else to do. Any info would help.
Old Jan 20, 2005 | 04:02 PM
drdisco69's Avatar
Default Re: Kinda weird (siblueg)
coughcoughheadgasketcough
Leak down and compression test anyone?
Old Jan 20, 2005 | 05:05 PM
siblueg's Avatar
Default Re: Kinda weird (drdisco69)
compression test revealed 240 psi all the way across, doesnt burn ANY antifreeze either
Old Jan 21, 2005 | 11:56 AM
siblueg's Avatar
bump
Old Jan 21, 2005 | 05:49 PM
johnnylawless's Avatar
Sounds Like Valve seals and possibly valve guides
Old Jan 23, 2005 | 08:22 AM
siblueg's Avatar
Default Re: Kinda weird (johnnylawless)
problem solved , it was fpr
Modified by siblueg at 4:03 PM 2/4/2005
S2SLOW
Honda S2000
12
Nov 6, 2007 08:48 AM
Triblade
Feb 21, 2006 06:15 PM
RCautoworks
Sep 1, 2005 11:16 PM
SixguN
Apr 20, 2005 04:07 PM
GOTNOS
Apr 16, 2003 04:37 PM
