eagle ge sleeved block having problems sealing help!
Old Jan 19, 2005 | 07:53 AM
sleepyeg6's Avatar
Default eagle ge sleeved block having problems sealing help!
ok i had my block sleeved by golden about a year ago it is the HD-SERIES 81.5mm bore and o-ringed i'm just getting around to putting it back togther well to day i put the head gasket on it first srayed it with copper spray on both sides then i installed arp head studs and the torqued it in the sequence the manuel says and i torqued it to 80ft pounds like ge recomends well where the head and block meet it seems to be staying wet it's not gueshing out or anything but you can see that it is wet and thats on the timing belt side and the dizzy side i called ge today and the guy told me oh you must not of torqued it right and that i didn't do it in the sequence but i told him i did then i asked could it be that one of the sleeves sunk he was quick to say no that's in possible. so i was just woundering if any of you guys have had this problem and how did you fix it any help would be great thanks
Old Jan 19, 2005 | 07:59 AM
b18bturbo's Avatar
Default Re: eagle ge sleeved block having problems sealing help! (sleepyeg6)
is your oring installed correctly in the groove. and what hg are you using factory.
Old Jan 19, 2005 | 08:04 AM
m R g S r's Avatar
what block? ls-vtec? Did you install the dowel pins correctly?
Old Jan 19, 2005 | 08:22 AM
PrettyLude's Avatar
Default Re: eagle ge sleeved block having problems sealing help! (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">is your oring installed correctly in the groove. and what hg are you using factory.</TD></TR></TABLE>
Old Jan 19, 2005 | 08:25 AM
sleepyeg6's Avatar
i'm using a oem head gasket and yes the o-rings are in the groove and it's a 94 gsr motor head and block and by the way just drained oil and it is milky i think it's mixing oil and antifeeze
Old Jan 19, 2005 | 08:52 AM
X-Mazda 3 Racer's Avatar
With our new sleeves, you should not have any issues what-so-ever. There are a few things to consider.
1. Were the dowel pins checked to be sure they are not holind the head up?
2. When the copper wire was installed, did you make sure there was no overlap where the wire butts together?
3. Did you make sure your head was flat before installing everything? Also making sure there was no debris on the mating surfaces?
4. What headgasket, head and block combo are you using?
You say the oil looks milky and that the headgasket is wet. The only thing I can think that could cause that is improperly installed o-ring wire or the dowels holding the head up a bit.
All these factors can play a roll in the success of your block. Our blocks are 100% guaranteed not to have any problems, I stand behind that 110%
Old Jan 19, 2005 | 09:20 AM
sleepyeg6's Avatar
i said i was using a b18c1 complete motor yes it is a oem head gasket yes the copper wire was installed by ge this is the first time im' putting it togther head was checked for flat ness yes there was no debris on either one thanks as for the dowel pins i 'd have to look in to it but the head is sitting completely flat i'm not trying to talk trash on ge i just want to know whats up with my block so i can drive my car again thats all and yes after i ran the motor tell it go t up to temp to see if it would dry up then i drained the oil and it was milky so ive come to the conclusion thats it's mixing oil and antifreeze could the sleeves have sunk by chance ???????????
Old Jan 19, 2005 | 09:25 AM
Don't take me the wrong way, I am on your side here. No need to get hostile with me. I just wanted to be sure that all the ducks are in a row before anything else. I can honestly say that since we started with the HD sleeve design and install, there has not been one instance of error anywhere. I just do see anything being wrong with your block, but I am willing to go through everything as much as I can with you to get this thing fired up and running again
Old Jan 19, 2005 | 09:46 AM
sleepyeg6's Avatar
Default Re: eagle ge sleeved block having problems sealing help! (GoldenEagleMfg.com)
no i'm just a little frustrated that's all i don't no what to do or say ive checked everything i can't figure out why it woulde be doing it also i just want it right and to run thats all
Old Jan 19, 2005 | 04:27 PM
earl's Avatar
Throw a can of stop leak in it and see if that will fix the problem. It has worked for others
a1320honda
Jun 25, 2009 07:31 PM
V8 BAIT
Jul 1, 2004 01:18 PM
Bnjmn
May 12, 2003 09:45 AM
Patron
May 3, 2003 03:28 PM
Turbo Lude SH
Nov 22, 2002 01:52 PM
