cylinder misfire
Old Jan 18, 2005 | 07:30 PM
wong's Avatar
Default cylinder misfire
Recently driving CEL poped up, had the code checked later on by a friend, it says something about cylinder misfire... cylinder 1. I don't know what have caused this... the only thing that I could think of is that lately I drove the car for a week or so w/o an air filter. But that shouldn't cause ignition or even misfire problems? Some input needed. Car is a 96 accord 5pd with over 100k on it. Everything in the engine stock except for some cheap intake tube I slapped on there.
Old Jan 18, 2005 | 07:38 PM
fknslmd's Avatar
Default Re: cylinder misfire (zhoujieLun)
i'd try replacing your distributor cap and rotor and reset the ecu, thats most likely your problem.
Old Jan 19, 2005 | 03:50 PM
matt_in_sd's Avatar
Was that the only code? Reset it and see if it comes back.
Old Jan 19, 2005 | 03:53 PM
hondadude's Avatar
Try a new set of NGK spark plugs.
Old Jan 19, 2005 | 04:36 PM
SuperSlow's Avatar
Default Re: cylinder misfire (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Try a new set of NGK spark plugs.</TD></TR></TABLE>
That is what I did last week when I pulled CEL74. No problems since.
Old Jan 19, 2005 | 04:48 PM
srfnscubamunkey's Avatar
Default Re: cylinder misfire (SuperSlow)
you culd sucked something in you tube
just replace plugs wires cap and rotor
rnl04
Jun 23, 2005 07:11 PM
sk8
Nov 17, 2004 02:54 PM
Kevin Cliff
May 5, 2004 04:17 PM
kinvid22
Mar 15, 2004 09:09 AM
youngkow
Apr 7, 2003 09:37 AM
