Code 71, what to replace?
Old Nov 17, 2004 | 08:58 AM
sk8's Avatar
sk8
Default Code 71, what to replace?
Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
I am getting this code again. First time a new set of spark plugs fixed it. The plugs can't be more then a month old.
What should I replace or test? Distrib, wires? All parts are original and have 110k on them.
Please help me as for I am at work with an hour drive home.
Thanks in advance.
Old Nov 17, 2004 | 09:00 AM
sk8's Avatar
sk8
Default Re: Code 71, what to replace? (scott k)
Btw, the cars runs but very rough.
Old Nov 17, 2004 | 09:02 AM
cheezthis's Avatar
Check the plugs first if you can first...make sure they didn't mess up already.
I know my car smoothed out when I changed plugs, wires, cap, and rotor.
Old Nov 17, 2004 | 09:04 AM
sk8's Avatar
sk8
Default Re: (cheezthis)
I forgot. I replaced the cap and rotor not too long ago.
New plugs and wires, ok. Would the distributor throw its own code if bad?
Old Nov 17, 2004 | 09:25 AM
dandc2's Avatar
Default Re: (scott k)
do a compression test
Old Nov 17, 2004 | 09:35 AM
wpsadmin's Avatar
I have the same exact thing, code71, but after i checked the code, the engine light went off, and never came on again
I have replace spark plugs only, the car has 90k miles on it. (runs smooth, but getting 20/miles per gallon)
I am thinking to replace the wires and cap and rotors soon. If I figure out how to do that.
Old Nov 17, 2004 | 10:15 AM
sk8's Avatar
sk8
Default Re: Code 71, what to replace? (wpsadmin)
What does compression have to do with this?
on lunch, i jiggled the wires around on dist and now it runs ok.
I hope new wires after work will fix it for good.
Old Nov 17, 2004 | 10:18 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scott k &raquo;</TD></TR><TR><TD CLASS="quote">What does compression have to do with this?
I hope new wires after work will fix it for good. </TD></TR></TABLE>
yeah.. at 110k and still on the originals, there's a mighty good chance your wires are shot.. I replaced mine at 60k..
Old Nov 17, 2004 | 12:56 PM
Gotballcancer
Guest
Posts: n/a
I got this code when I melted a piston, and ya it ran like crap. Do a compression test.
Old Nov 17, 2004 | 02:54 PM
sk8's Avatar
sk8
Default Re: (bushisafascistpig)
New wires = runs like butta.
Thanks all
Coolero
11
Oct 25, 2009 11:17 PM
CUTTERSPOOL
Jun 16, 2009 05:11 PM
rnl04
Jun 23, 2005 07:11 PM
rukawa1one
Feb 15, 2005 05:53 PM
EK_vzla
Aug 30, 2004 01:39 PM
