loss of power after VTEC engagement
heres the deal
i have a y8 motor. i recently swapped out the ITBs to go back to the skunk2 manifold and SRI. When i drive the car normally, its fine and drives nice and smooth. but, if i get on it and get in VTEC, i have a noise which sounds like air is escaping and it feels like im losing some power up top. i have no CEL's and no signs of any fluilds leaking anywhere....................someone have any imput???
never really had a chance to get much tuning done..................right now, the AFC is set all to 0 settings...............main thing is the noises im hearing at high RPMs.................had the same noises after the ITBs went on...........
did you put a new intake manifold gasket on? it could also be the intake, if there is a small hole in it it will hiss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">never really had a chance to get much tuning done..................right now, the AFC is set all to 0 settings...............main thing is the noises im hearing at high RPMs.................had the same noises after the ITBs went on...........</TD></TR></TABLE>
well according to your sig you are tuned. but eh. can you describe the sound, like dose it sound like something is breaking?
not soo much that something is breaking, it sounds like a high pitched squeal that cuts on and off really fast when the car gets to about 6k in the powerband. i did replace the IM gasket and checked all lines goin into and from the manifold...............
b20accord
May 17, 2019 11:41 AM
leondx
10
Mar 7, 2010 12:36 PM
DCxMagus
Sep 18, 2007 02:34 PM
