loss of power after VTEC engagement
heres the deal
i have a y8 motor. i recently swapped out the ITBs to go back to the skunk2 manifold and SRI. When i drive the car normally, its fine and drives nice and smooth. but, if i get on it and get in VTEC, i have a noise which sounds like air is escaping and it feels like im losing some power up top. i have no CEL's and no signs of any fluilds leaking anywhere....................someone have any imput???
Re: loss of power after VTEC engagement (Superdragr45)
well itb's add the most power up top, so could it be your just used to the more power?
Re: loss of power after VTEC engagement (Soccerking3000)
was the car tuned with the itb's? cause the air fuel ratio will be real different so you may need to retune
Re: loss of power after VTEC engagement (sohcvtec1995)
never really had a chance to get much tuning done..................right now, the AFC is set all to 0 settings...............main thing is the noises im hearing at high RPMs.................had the same noises after the ITBs went on...........
did you put a new intake manifold gasket on? it could also be the intake, if there is a small hole in it it will hiss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">never really had a chance to get much tuning done..................right now, the AFC is set all to 0 settings...............main thing is the noises im hearing at high RPMs.................had the same noises after the ITBs went on...........</TD></TR></TABLE>
well according to your sig you are tuned. but eh. can you describe the sound, like dose it sound like something is breaking?
not soo much that something is breaking, it sounds like a high pitched squeal that cuts on and off really fast when the car gets to about 6k in the powerband. i did replace the IM gasket and checked all lines goin into and from the manifold...............
b20accord
05-17-2019 11:41 AM
leondx
10
03-07-2010 12:36 PM
DCxMagus
09-18-2007 02:34 PM
