d16z6 and d16y8 how do they differ
Old Jan 18, 2005 | 04:11 PM
dornon13's Avatar
Default d16z6 and d16y8 how do they differ
Well the big questiion i need answered is if the blocks are the same...i have a y8 and i am wondering if i can buy a z6 block and it will be EXACTLY the same. but also i have heard they are very similar and i figured a thread discussing the differences might be interesting. thanks
Old Jan 18, 2005 | 04:18 PM
Soccerking3000's Avatar
Default Re: d16z6 and d16y8 how do they differ (dornon13)
y8 has a better flowing intake manifold, and the combustion chambers are slightly smaller to bump up the compression. While the Z6 has a better flowing head because the intake ports are equally split to each valve while the y8's are offset to create a swirling effect into the combustion chamber.
Old Jan 19, 2005 | 04:44 AM
jlacoy82's Avatar
71.192.16.183
Default Re: d16z6 and d16y8 how do they differ (Soccerking3000)
Isnt the oil major difference between the z6 and y8 is the oil pumps, and the location of the dipstick?
Old Jan 19, 2005 | 04:57 AM
MI KENT's Avatar
i would like to know ALL the differences. also i have a jdm d15b vtec engine in my car. the p08 head are the same (from what i've heard) as the head on the z6. so which head is better for an all motor d-series build?
Old Jan 19, 2005 | 09:01 AM
civic-4-ges's Avatar
Default Re: (MI KENT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI KENT &raquo;</TD></TR><TR><TD CLASS="quote">i would like to know ALL the differences. </TD></TR></TABLE>
Did you say ALL the differences??
There are many, too many to go over piece by piece. Most are not substantial
Y8 head for all motor!!! CC's are shaped to help prevent detonation
Old Jan 19, 2005 | 01:19 PM
dornon13's Avatar
Default Re: (civic-4-ges)
does the y8 head help against detonation on a FI motor too?
Old Jan 19, 2005 | 01:33 PM
Default Re: (dornon13)
yes to a degree
Old Jan 19, 2005 | 02:37 PM
PRcivicHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">y8 has a better flowing intake manifold</TD></TR></TABLE>
Everything else I agree with except that... The fat short plenum of the Y8 manifold makes it produce more power in low-mid rpms... While the Z6 manifold makes more in high rpms...
There was thread that gave an in-depth explanation a long time ago....
Also if he uses the z6 block he will slightly bump compression, i believe...
SpdKilz23
10
Apr 11, 2009 02:48 PM
98jdm_coupe
Apr 15, 2004 09:28 PM
ArchAngel Sabastian
15
Dec 29, 2003 11:04 AM
DRKSol
Sep 5, 2003 07:05 PM
130hp
11
Aug 9, 2002 03:32 AM
