More graphs of my Dyno run.
Old Jan 18, 2005 | 02:52 PM
PaImportTuner's Avatar
Default More graphs of my Dyno run.
Mods:
short ram intake
Megan Racing 4-1 header (from SiRiUsWeRks)
testpipe
Thermal Classic with fart can.
Spoon program chipped in my PR3
1 o2 sensor(2ndary o2 wire spliced into primary) everything else is STOCK in and on engine.
I didn't get any runs with stock b16a1 manifold and 2 o2 sensors.
I needed more fuel i kept leaning out up top.
I called up and got my other dyno graphs printed out in speed and rpm, the one before was just seconds.. i want you to let me know what you think of these.
Old Jan 18, 2005 | 03:04 PM
Sobe_Death's Avatar
wow, you are much more brave than I running those AFR's that lean, mine are at least 13.6:1 from 3000 on up to redline.
Old Jan 18, 2005 | 03:40 PM
altoid's Avatar
Default Re: (Sobe_Death)
correct me if im wrong but i was under the impression that b16s stock made 150 hp?
Old Jan 18, 2005 | 03:44 PM
Wraith's Avatar
Default Re: (altoid)
that dyno is power to the wheels, that 160 hp that the engine is rated at is at the flywheel
Old Jan 18, 2005 | 04:09 PM
shocker's Avatar
dude your running kinda lean even with that cheap,kinda weird might wanna tune it some more
Old Jan 18, 2005 | 04:14 PM
altoid's Avatar
Default Re: (Wraith)
hah, yeah i completely forgot about that(the flywheel hp). you'll make more power running lean than you will running stoich or rich, but engine life is compromised, you decide whats more important
Old Jan 18, 2005 | 05:19 PM
b16_madman's Avatar
hmm, tq. looks gutless, could be the differing dynos.
Old Jan 19, 2005 | 05:28 AM
Default Re: (B16_madman)
i have an EGT probe/gauge and autometer a/f and they are both on the dot with my a/f. so i can tell when i'm lean.
Old Jan 19, 2005 | 10:32 AM
Default Re: (PaImportTuner)
why the hell would my torque be that way?
Old Jan 19, 2005 | 11:12 AM
b18CrxSi91's Avatar
71.179.86.205
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">why the hell would my torque be that way? </TD></TR></TABLE>
It's a b16?
Old Jan 19, 2005 | 12:49 PM
b16_madman's Avatar
Default Re: (b18CrxSi91)
I dunno, my tq. is low yes, but it's flat at least.
Old Jan 20, 2005 | 11:01 AM
Sobe_Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">i have an EGT probe/gauge and autometer a/f and they are both on the dot with my a/f. so i can tell when i'm lean.</TD></TR></TABLE>
no offense, but if you look at your AF curve, it is going in the wrong direction. as rpm's increase, the A/F ratio should be falling slightly towards rich, not climbing towards lean.
Old Jan 20, 2005 | 04:53 PM
i know, im running lean this isn't new news. i have aquired 190 walboro, fpr to fix problem. since my stock dx pump can't pump for the b series.
null.
Feb 27, 2005 09:21 PM
PaImportTuner
55
Jan 15, 2005 09:24 PM
BoostedD15B7
Jan 26, 2004 10:18 PM
Mr. Softee
Apr 29, 2003 01:00 PM
sneakychaos
May 10, 2002 02:42 PM
