go fast parts
hey this might be a dumb topic i know but i want to know what you guys did to your car to get power out of it but still spend less amount of money. Im only 17 so i do not have much money to spend on my car. I have a 93 civic ex coupe. it has intake an soon to be es oval exhaust. lowered on tanabe springs. can someone help me out with some tips or pointers to make my car quick but reliable and cheap. thank
Rule number one nothing can be quick, reliable and cheap. you can only pick two. also if you are on a budget then just do boltons. I have the same motor with bolt ons and im in the low 15's.
not much you can do for big gains... you can get a high flow cat.... advance the timing a couple degrees.... but heres the magic system... Cheap,Fast,Reliable.... now you can pick 2 of these.. but you lose the third.... so cheap+fast= un reliable... ect...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Rule number one nothing can be quick, reliable and cheap. you can only pick two. also if you are on a budget then just do boltons. I have the same motor with bolt ons and im in the low 15's.</TD></TR></TABLE>
you must be able to launch perfectly (give me some tips)
anyway, cam and cam gear, tune it right and youll be able to get power...cam is like 200, and gear is like 80
Firebirda7x
83
Apr 15, 2011 05:45 PM
ChrizXx
65
Apr 8, 2010 10:03 PM
