Clutch fluid leaking.. i know you guys know the diagnosis.
Its been two days since i have been slowly loosing clutch pressure. I checked it out finally when i had to - no pressure at all.. its 10 degrees right now, so i did it as fast as possible... anyways i filled up the fluid etc and bled the line and i couldnt find a leak at first but then i looked under the dash - its leaking out of there the pedal goes into (clutch pedal). Is this the clutch cylender?? My brother thinks that little rubber thing in there is just loose - he's looking at it now, but i didnt think that was possible. Anyways.. i searched and couldnt find anything so do u guys have any links or info on this??
thanks!!
Edit: almost forgot .. its a gen 5 civic , d16z6 (urg) with obviously a hyrdo tranny. This is my beater car since i got the bike and its 100% stock on the motor/trans - just lowered and rims bc of the way i like to drive.. lol
thanks!!
If it's leaking it needs a new clutch master cylinder. It would be a good idea to replace the slave to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">If it's leaking it needs a new clutch master cylinder. It would be a good idea to replace the slave to.</TD></TR></TABLE>
exactly it. Mine did the same thing a while back.
