96-98 to 99-00 Front end conversion...
Anyone done this? Any problems with it? HELP ME!!
Get with me on aim if you got some info; iruleyou21
Modified by 1998 hatch dx at 5:16 PM 1/18/2005
Its called the search button. Many people has responded to these questions before.
Edited by Ricey McRicerton:
-1% for your not following the forum guidlines. I strongly suggest you as well as everyone else reads the revised forum guidlines.
https://honda-tech.com/zerothread?id=1118700
Its impossible! No one would do such a thing!!!!
Or wait.....yes its possible, need the fenders/bumper/hood off the donor car, and some other garbage maybe? Its all in the search.
You should have no problem, everything should bolt up, like the head lights, fender, hood, front bumper, but I'm not sure if you have to change your radiator support or not. Some one enlighten us.
i have done a few of them and they are very simple to do if you have all the correct parts .the only thing that you have to modified is the brackets that holds the top of the bumper cover because the 96-98 are wider than 99-00 .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorgie583 »</TD></TR><TR><TD CLASS="quote"> the brackets that holds the top of the bumper cover because the 96-98 are wider than 99-00 .</TD></TR></TABLE>
I got this on my car, the front bumper might be a tiny bit wider but the fenders incorporate the change into the car. everything bolts right up no problems. you can use your stock core support.
i think i may have got the wrong bumper...body shop guy says that the hood's lines and the bumpers lines are about an inch off...i've got 99-00 hood, fenders and lights...the bumpers beign a bitch..
To do the conversion you will need:
hood
lights
fenders
bumper
grill
from a 99-00. You can also replace the bumper support, or just cut the tabs off of the 96-98 where there's interference.
hood
lights
fenders
bumper
grill
heres the bolt on method
https://honda-tech.com/zerothread?id=790135
theres also another thread describing how to do it by switching radiator supports. it just depends on how much work u want to put into it.
CarFanatic26
12
Nov 30, 2018 08:48 PM
dudeomega2000
12
Jun 13, 2008 01:29 PM
JLEK
Jan 10, 2007 05:44 PM
Normielove
14
Feb 22, 2005 12:15 AM
blkgsr03
25
Jan 1, 2003 12:18 PM
