For those of you with Power Inverters
Old Jan 17, 2005 | 03:03 PM
litterbox's Avatar
I am a (Trial User) Army
Default For those of you with Power Inverters
Hey,
My plan: I'm going to make a bracket to mount my power invertor into my glovebox so I can get constant power to my laptop when I watch movies during roadtrips. The power inverter has a power and ground wire.
Question: Should I just run the red wire directly to the battery and the ground wire to a ground on the chassis? Or do I have to run the ground wire to the negative on the battery?
Thanks.
Old Jan 17, 2005 | 03:05 PM
ablack934doorcivic's Avatar
Default Re: For those of you with Power Inverters (litterbox)
on the body should be fine you don't want to long of a ground wire
Padawan's Avatar
Darth ModerVader
Ground it to the chassis and fuse the positive lead from the battery. Also, in the future you might want to post questions of this sort in a more appropriate forum.
Old Jan 17, 2005 | 03:07 PM
litterbox's Avatar
Default Re: For those of you with Power Inverters (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Ground it to the chassis and fuse the positive lead from the battery. Also, in the future you might want to post questions of this sort in a more appropriate forum. </TD></TR></TABLE>
Thanks for you answer. Sorry about the wrong forum.
niceprelude
Dec 24, 2008 07:13 PM
roller3804
Jan 21, 2008 09:48 AM
iwantspeed
Honda Civic (2001 - 2005)
Nov 29, 2006 08:30 PM
User 42624
Jul 19, 2005 11:41 PM
team703
Sep 14, 2004 06:30 PM
