For those of you with Power Inverters
Hey,
My plan: I'm going to make a bracket to mount my power invertor into my glovebox so I can get constant power to my laptop when I watch movies during roadtrips. The power inverter has a power and ground wire. Question: Should I just run the red wire directly to the battery and the ground wire to a ground on the chassis? Or do I have to run the ground wire to the negative on the battery? Thanks. |
Re: For those of you with Power Inverters (litterbox)
on the body should be fine you don't want to long of a ground wire
Ground it to the chassis and fuse the positive lead from the battery. Also, in the future you might want to post questions of this sort in a more appropriate forum.
Re: For those of you with Power Inverters (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Ground it to the chassis and fuse the positive lead from the battery. Also, in the future you might want to post questions of this sort in a more appropriate forum. </TD></TR></TABLE>
Thanks for you answer. Sorry about the wrong forum. |
