Need clutch advise..Please help!!
Old Jan 17, 2005 | 12:30 PM
TurboJesse
Guest
Posts: n/a
Default Need clutch advise..Please help!!
now that my motor is all said and done its time to choose a clutch..Im hesitant to make the step to a twin disc as the car is mostly for cruising/highway fun and won't see the track all the time. Setup is a 84.5mm LS block, GSR crank, JG Race head, GSR tranny, LSD. Turbo will be sc61 and goals are 550ish on race gas. Will any single disc (or streetable/affordable twin) be able to hold this power?
Old Jan 17, 2005 | 02:05 PM
95GSRTT
Guest
Posts: n/a
Default Re: Need clutch advise..Please help!! (Mpir3)
anything but RPS
Old Jan 17, 2005 | 02:19 PM
Ben Huynh's Avatar
The ACT XX-R6 or ClutchMasters Stage 5 will hold the power you're looking to put down.
Old Jan 17, 2005 | 03:13 PM
SSVTi's Avatar
Default Re: Need clutch advise..Please help!! (ben@importparts.com)
Which of these has a higher capacity, the ACT or CM? Cause I cant find the torque specs of the CM Stage 5. I know the ACT is 487 ft./lbs
Andy
Old Jan 17, 2005 | 03:19 PM
tepid1's Avatar
I have the Exedy Stage2 thick (different from thin) with the 8lb flywheel. I have only had it for 300 or so miles and I love it. I think that the holding capacity was around 450ft/lbs of torque. I would recommend this to anyone with FI because it spools the turbo quickly
Old Jan 17, 2005 | 05:34 PM
NVturbo's Avatar
O.G. triple O.G.
Definitely A.C.T.!!!!
Old Jan 17, 2005 | 05:43 PM
Alchemist's Avatar
Default Re: Need clutch advise..Please help!! (NVturbo)
Check out an Action 2MD
dcsports
Aug 19, 2013 06:55 AM
Listerofsmeg
Transmission & Drivetrain
Aug 17, 2010 06:50 AM
90Rexx
Jan 9, 2010 10:08 AM
bigdgsr
Jan 17, 2008 08:59 AM
HomeDepotMade
Jan 31, 2007 05:45 AM
